2002 Taurus 3.0 Vulcan Bucking under Acceleration - Taurus Car Club of America : Ford Taurus Forum
 4Likes
  • 3 Post By jag1959
  • 1 Post By kekaye56
post #1 of 9 (permalink) Old 07-03-2019, 07:23 PM Thread Starter
Have been having intermittent Problems with bucking under acceleration. Has been happening on an onramp to the Interstate at about 40 mph. if you lift and apply slowly you can slowly get up to speed Speed limit 60mph.
Now it also happens at the change less than a mile away for 60 to 70mph.
I drove it the other day first drive of the day getting on the interstate up to 75mph no problem. Later in the day bucking encountered.
Was informed that it stalled in traffic and had to be pushed out of way. Restarted a few minutes later. I was informed it stalled in a parking space 6 months ago and restarted a few minutes later.
My Ultragauge obdII reader show no codes.
I Like FE is offline
post #2 of 9 (permalink) Old 07-03-2019, 07:31 PM
Play Nice or Don't Play
jag1959's Avatar
Engine: 3.4L Yamaha V8
Have you thoroughly checked the coil pack for cracks? Often they will not throw a code
It's SHO time!
jag1959 is offline
post #3 of 9 (permalink) Old 07-03-2019, 10:00 PM
I had a buck at 45 mph and thought it was the trans but it was a low side ignition coil problem fixed by a new Motorcraft coil.
post #4 of 9 (permalink) Old 07-04-2019, 06:46 AM
Year: 2017
Engine: 3.5L Cyclone V6
Have you replaced the fuel filter?
Hornswaggle likes this.
kekaye56 is offline
post #5 of 9 (permalink) Old 07-04-2019, 08:31 AM
Fitz8710's Avatar
I had a 91 f150 that did this. It was rather scary as it would feel like the transmission was going to rip out of the under carriage lol. It turned out to be a bad PIP on the distributor. I know our 3.0s dont have distributors but i would start with the coil, wires and plugs ( like jag said) then the fuel delivery system.
Fitz8710 is offline
post #6 of 9 (permalink) Old 07-04-2019, 11:08 AM Thread Starter
BWD coil installed 3 years ago. Will try water spray bottle mist.
Fuel filter replaced 2 years ago. Not sure how working cold vs hot lead to fuel filter?
Thanks for the input will forge on with these suggestions.
post #7 of 9 (permalink) Old 07-04-2019, 07:58 PM
Had the Hall effect system fail on '85 LTD and ran but in some horrible way until it got home then would not start again.
As to misfire, Son had F150 with the inline 6, 300ci with OBDII so coilpack but that engine ran the engine as one unit while most Ford V-6 operate as two 3 cylinder units. Son's with 5 speed manual and a bad plug wire would misfire under power and then ran awful for a couple seconds and recover then miss again. Wires were new but one was open. Very easy engine to do wires, plugs and such. Theory, misfire makes for a false lean so the engine richens up then quickly leans it back to correct and lean makes misfire happen again.
I have had misfires on Bulls and it is a pain. Coilpack is a weak link in the system.
post #8 of 9 (permalink) Old 07-08-2019, 08:54 PM
Year: 2000
I immediately wondered about fuel system too, as hot weather can mean vaporlock especially when hot soaking. I had rough running issues the past year and a half in the heat. Weak fuel pump was diagnosed with a fuel pressure and volume tester (which is super easy to do with the schrader valve on my fuel line). The tester is loanable, though the deposit is over $100. The other piece of the puzzle I just realized in March was my alternator dying and producing undue load at idle and low speeds.
Now in your case it's for acceleration, but there again, if you had a weak pump or a constriction of fuel delivery somewhere, that could maybe be a cause.
On my 3rd of 3 Tauruses
ProgrammerMech is offline
post #9 of 9 (permalink) Old 07-10-2019, 06:11 PM
Engine: OTHER
Similar problem for me was cured by coil replacement. I got a motorcraft unit off Amazon.
barryhayes is offline
Chasing the P1633 gremlin on 2002 Taurus 3.0 ohv hrtull Maintenance and Repair 13 03-11-2019 07:42 PM
Josh's 2002 Taurus SEL Premium Josh Taurus and Sable Project Log 299 12-30-2016 04:20 AM
2002 FORD TAURUS OBDII MONITORS NOT READY AFTER 261 MILES ! Driver-2002 5th and 6th Gen Maintenance and Repair 6 10-01-2014 09:30 PM
2004 Taurus 3.0L Duratec harsh surge under heavy acceleration AGrayson84 Engine and Drivetrain 14 01-09-2014 12:30 PM
