Need help changing window lift motor 07 taurus - Taurus Car Club of America : Ford Taurus Forum
 2Likes
  • 1 Post By pageyjim
  • 1 Post By blondechic451
post #1 of 9 (permalink) Old 06-14-2019, 10:42 AM Thread Starter
My window lift motor broke off my regulator and my driver window quit working. So typical with these cars. Should be a recall on that. Well I took the door off and I'm not sure how to put that part back in the car. Do you just screw it back in place or does the gear on the lift motor have to attach to the regulator a certain way?
Edit:
I don't think my regulator is in the right place to put it back on. When it broke off. My window was half way down and I had to push it up with my hands because it wouldn't work anymore.
blondechic451 is offline
post #2 of 9 (permalink) Old 06-14-2019, 11:48 AM
Maybe this is a helpful video.
https://www.1aauto.com/how-to-instal....com/video/797
pageyjim is offline
post #3 of 9 (permalink) Old 06-14-2019, 12:46 PM Thread Starter
Thanks. I'll just pay someone to take the regulator out. I wasn't wanting to do that much work. Was hoping I could screw that motor back in place without taking the track out but that's not happening.
post #4 of 9 (permalink) Old 06-15-2019, 09:24 AM Thread Starter
One more question before I give up trying.
Can you put the lift motor back in without taking the regulator out? If you can, should the window be in the up or down position? Having trouble figuring out how the gears fit into the regulator.
Thanks!
post #5 of 9 (permalink) Old 06-15-2019, 10:20 AM
TollKeeper's Avatar
Model: Mercury Montego
You can, but its going to be nearly impossible because of the mount locations. Its not really that hard to pull out the motor and regulator as an assembly. If you dont have the tools, than I understand taking it to the shop.
Brian - Carpe Diem
2005 Mercury Montego 52k
2004 GMC Envoy XUV 182k
TollKeeper is offline
post #6 of 9 (permalink) Old 06-15-2019, 10:40 AM Thread Starter
I have the tools but I don't have bolts/nuts to put the regulator back in if I'd have to drill out the rivets. Would have to go buy some but clueless on what size I'd need.
post #7 of 9 (permalink) Old 06-15-2019, 10:41 AM Thread Starter
My motor is already out.
post #8 of 9 (permalink) Old 06-15-2019, 10:54 AM
TollKeeper's Avatar
Well, per the video, he is using a 5/16 inch drill bit, so you would want something fairly close in that size. Maybe 1/4 inch or so. They would need to be fairly short, maybe 1/2 inch long or so.
Brian - Carpe Diem
post #9 of 9 (permalink) Old 06-15-2019, 11:25 AM Thread Starter
Wasn't that hard once I figured out what I was doing. Hahaha. But hey, it works now! Thanks for helping.
Doesn't matter if the window is in the up or down position. Directions said the gear needed to lock in place so I got a bit confused there. Was nothing to lock in place. Unscrew it, grease the gear on the new part, and put it back in. End of story.
Spark Plugs unit731 Engine and Drivetrain 19 06-18-2018 01:30 PM
2003 Ford Taurus SES power window problems oldcrowmedicine Maintenance and Repair 3 03-10-2017 06:02 PM
2000 Taurus misfire with cylinder # changing gyusung Maintenance and Repair 5 02-27-2016 05:24 PM
New member, 2nd Taurus, 4th Ford, former GM'er Rob Lee Introduction Forum 11 06-06-2014 09:57 AM
1999 Taurus Passenger window frame evadfa Aesthetics, Interior, Wheels and Tires 0 05-04-2013 12:57 PM
