Stripped oil pan bolt head - Taurus Car Club of America : Ford Taurus Forum
 4Likes
post #1 of 12 (permalink) Old 05-26-2019, 10:04 AM Thread Starter
Anyone have any experience welding a nut to an oil pan bolt? I have one that is very badly rounded, and can't think of any other way to get it off. I've seen videos of using a flux core welder to weld a nut to the bolt head.
mplieb is offline
post #2 of 12 (permalink) Old 05-26-2019, 10:20 AM
I've never personally got that to work the bolt just breaks off. If it's a 6 sided nut you might could file the sides enough to get a 6 point wrench or socket onto it.
Sent from my SM-J727T1 using Tapatalk
spellman1989 is offline
post #3 of 12 (permalink) Old 05-26-2019, 10:45 AM
Have you tried visegrips/pipewrench?
post #4 of 12 (permalink) Old 05-26-2019, 11:05 AM
I have used these for the exact same purpose on my oil pan. I have Craftsman brand.
Name:	Bolt extractors.jpg
post #5 of 12 (permalink) Old 05-26-2019, 11:59 AM
Year: 02
rsteve56 is offline
post #6 of 12 (permalink) Old 05-26-2019, 12:41 PM
^+1. I've got both the Craftman and Irwin, lol.
post #7 of 12 (permalink) Old 05-29-2019, 06:09 PM
Alternative
Forget about it. Go get an oil extractor from Harbor and siphon it out. They usually have a coupon where you can get it for $49. https://www.harborfreight.com/automo...tor-62643.html
jazzwineman is offline
post #8 of 12 (permalink) Old 05-29-2019, 08:22 PM
Year: 1999
Model: Ford Taurus Wagon
Pipe wrench will get it of very easily.
james27613 is offline
post #9 of 12 (permalink) Old 05-29-2019, 08:33 PM
Unless the bolt is in incorrectly causing the rounded off head of trying to get it off before and you will just snap off the head of the bolt and have greater problems than before. This is why you should get a new bolt with each oil change- not costly to avoid this type of mess. Forget the bolt and pump it out.
post #10 of 12 (permalink) Old 05-29-2019, 08:34 PM
Why do some people think bolt is the oil pan drain plug? Am I wrong, but I am thinking the OP means the bolts that hold on the oil pan.
92 3.8 Head bolt order and torque punky482 Maintenance and Repair 1 09-09-2017 12:58 PM
Stuck bolt Earl Tnatza Suspension, Handling and Brakes 34 08-05-2016 07:27 PM
Extracting Stripped Bolt from Tensioner AceOfCircles Maintenance and Repair 21 11-24-2014 07:41 PM
Stripped front sub-frame bolt help tvtaurus Suspension, Handling and Brakes 36 08-03-2014 08:32 PM
Tensioner Bolt Hole Threads Stripped! rhyvun Maintenance and Repair 17 01-22-2014 07:03 PM
