03 Duratec with P0171 / P0174 - Page 3 - Taurus Car Club of America : Ford Taurus Forum
 3Likes
post #21 of 24 (permalink) Old 07-28-2019, 11:10 AM
Year: 2002
Welcome to the 71 code nightmare from hell.
I have spent literally $1,000 trying to fix this same issue and have done everything.
Before you drive yourself into the poor house and/or insane asylum, try replacing the DPFE sensor.
It is behind the engine on the right side as you look at the motor. Remove the two bolts holding the throttle body on and disconnect the air intake from the filter housing and move it out of the way to get to it.
Two hoses, an electrical connection, and two 9 mm nuts holt it in place on the DOHC SES engine.
Sensor is available at Amazon for $20.00 or Autozone for $84.00.
Commander_47 is offline
post #22 of 24 (permalink) Old 07-28-2019, 11:15 AM
A faulty dpfe sensor usually throws p0401 or p0402 codes.
That would be my one concern and his codes indicate classic vacuum leaks. However if the hose attached to the sensor was not tight or was falling apart- what code would be set? Would he get the 0171 and 0174 along with 0401 and 0402?
Have you also checked your fuel injectors- that could definitely cause a lean condition.
TBB
jazzwineman is offline
post #23 of 24 (permalink) Old 07-28-2019, 01:45 PM
^ The dpfe hoses aren't vacuum hoses. They're heat resistant silicone sampling hoses coming off the exhaust manifold ports.
post #24 of 24 (permalink) Old 07-29-2019, 07:19 AM
Year: 2002
https://www.bluespringsfordparts.com...ed-p0171-p0174
Please read the above as posted by a FORD dealer.
A faulty DPFE will throw the 0171 code.
A faulty EGR will throw the 0401 code.
All I'm saying is....check this FIRST. It's only 20.00 as opposed to thousands and tons of time.
P0171, P0174, P0183, P0193 at same time jthomasv8 Engine and Drivetrain 9 01-09-2019 09:57 PM
Back again. 2007 Taurus P0174 code stored, P0171 code pending BullyforMe Maintenance and Repair 6 02-14-2018 09:39 PM
2006 Taurus Vulcan, P0174 and P0171 VAC leak in brakes? Spencer Morgan Maintenance and Repair 21 06-02-2016 07:47 PM
P0171 and P0174 on 2002 Duratec with most things replaced bighank Maintenance and Repair 13 11-06-2013 04:07 PM
You may post new threads
You may post replies
