2003 Water leak on Passenger Floor(possibly windshield) - Taurus Car Club of America : Ford Taurus Forum
 1Likes
  • 1 Post By kestas
post #1 of 8 (permalink) Old 05-14-2019, 03:01 PM Thread Starter
Hey everyone. New to the forum. I have been working on our family car for a while which is an 03 Taurus. This past winter we noticed that water was leaking in mainly starting at the driver floor. I pulled the cowl and found a whole bunch of leaves behind there. I removed them and verified the middle and side drains were working. The water leaks in when it rains. I took the A pillars off and ran a hose over the top of the windshield on the driver's side. I noticed the water on the lower drive corner of the body form inside the car. You wouldn't see it if the a pillar was on. I also noticed in the upper corner on the driver side the windshield seal seems to be fault as I can sort of see light coming through.
I am thinking it is the windshield that needs to be resealed if possible or replaced but I am not 100% certain as I can really point out the exact leak point.
In the picture I have provided you can see where the light is seen in the upper driver corner and the picture with the arrow is where I can see the water flowing then it drips down all over the dash components and onto the floor. (Has rusted a bunch of stuff under there also)
Thank you in advance. I am hoping I can fix this water issue with the forums help. Although I do think its the windshield I don't want to reseal or replace without full confidence.
ID:	208731   Click image for larger version
ID:	208733   Click image for larger version
ID:	208735   Click image for larger version
Jbird420 is offline
post #2 of 8 (permalink) Old 05-14-2019, 11:19 PM
Year: 02
That might not be light shining through a gap. It might be light reflecting off the sealer bead.
rsteve56 is offline
post #3 of 8 (permalink) Old 05-15-2019, 06:39 AM
Been running the AC lately?
post #4 of 8 (permalink) Old 05-15-2019, 08:48 AM
Been through a lot finding my issue with a driverside leak. Check out this thread. Also get ready to patch a rotted floor pan. I think my Taurus was leaking for years and running out holes in pan. After I patch pan I got two inches of water on the driverside the next rain.
https://www.taurusclub.com/forum/82-...-floorpan.html
post #5 of 8 (permalink) Old 05-15-2019, 03:43 PM
kestas's Avatar
I just went through this a week ago with my 2001 Sable. There was a telltale trail of water going down the carpet in the footwell. It was a quick find. It was leaking through the air cabin filter. Once you take the top plastic cowling piece off that's in front of the windshield, you'll see a plastic gutter that collects water and dumps it to the side. It must've shrunk over the years, allowing it to dump right into the cabin filter. I made an extension out of a plastic beverage container to solve the problem.
kestas is offline
post #6 of 8 (permalink) Old 05-15-2019, 03:51 PM
Pictures show the driverside but the title lists passenger side unless it has two sets of brake and gas pedals. What side is it???? .
post #7 of 8 (permalink) Old 05-15-2019, 07:03 PM
^^^ I assumed the text stating passenger side was correct...... thats why I asked if the AC was running recently, thinking plugged evaporator drain.
post #8 of 8 (permalink) Old 05-15-2019, 09:17 PM
I guess my mind interfaces with pics and I never processed the title and looked at pics first.
Passenger Side Water Leak (My Curse) Fixed ehwhite 5th and 6th Gen Maintenance and Repair 3 06-12-2018 01:22 PM
Wet passenger side floor board - documented fix shornsac Maintenance and Repair 12 07-18-2016 07:26 PM
Need help with the infamous water leak curse oldad Maintenance and Repair 8 04-03-2014 09:21 PM
HVAC Water Leak (Heater Hoses) the_intimidator_02 Maintenance and Repair 1 09-25-2013 10:38 AM
Check your drivers floor for water leak!! durasel Maintenance and Repair 5 04-12-2013 11:14 PM
