2001 Taurus - P0171 & P0174 - Taurus Car Club of America : Ford Taurus Forum
 5Likes
post #1 of 13 (permalink) Old 04-30-2019, 08:43 AM Thread Starter
Hello All;
OK.
I changed out the Coil Pack on our 2001 Ford Taurus (DOHC)
Cleared the codes, ran the car for about 100-miles.
And all of a sudden, it started to act up again.
The codes are:
P0171 & P0174
Banks 1 & 2 - Too Lean
I have checked for air leaks, and cannot find any.
I cleaned the MAF Sensor and that seemed to have helped.
So I cleared the codes again, and the two codes above are back again.
Any information on what to check next, or replace, would be great.
Thanks.
Wayne
carrzkiss is offline
post #2 of 13 (permalink) Old 04-30-2019, 09:55 AM
Moderator
99.9% chance you have a vacuum leak you havent found yet. .1% chance you have low fuel pressure.
What are the long term fuel trims on each bank at idle and with the engine under load (i.e., cruising at higher speeds)? High positive trims at idle that drop toward zero under load = vacuum leak.
What engine? Vulcan or Tec?
sheila and Automender12345 like this.
post #3 of 13 (permalink) Old 04-30-2019, 10:26 AM
had those same codes last month after i changed my spark plugs and coil pack. When i was changing the plugs in the back, I accidently pulled one of the hoses to the MAF out of place and had a vacuum leak. Once i put the hose back in place, the codes cleared.
Cfella is offline
post #4 of 13 (permalink) Old 04-30-2019, 11:05 AM
May also suspect uim & lim gaskets. Is the fuel filter due for a change? Any fuel pressure sensor codes? May check its vacuum hose for wetness/strong fuel odor.
post #5 of 13 (permalink) Old 04-30-2019, 09:35 PM Thread Starter
@sheila
No fuel smells.
@Cfella & Jeff K
I am going to take it apart tomorrow and see what might have happened.
I will post back my findings afterward.
post #6 of 13 (permalink) Old 05-01-2019, 01:25 PM Thread Starter
OK.
I took the manifold off the car.
Looked around and checked everything, and then put it back on.
When I started the car up, it revved up for about 2-seconds and then back down.
So far, it is running and sounding like it should.
I cleared the codes and will post by the end of the weekend, on rather the codes come back or not.
If they don't, then next week, I will take the car in for inspection and then plates. (Hopefully)
Quick question.
My son was told that at the beginning of 2019, some codes will no longer be counted for passing inspection.
P0442
Is the code that I have had for about 2-years on the car.
Will this code pass or will it hinder me from passing inspection?
post #7 of 13 (permalink) Old 05-01-2019, 03:07 PM
Iirc, some locales will let you pass with 1 cel code. Dunno about p0442 (small evap leak)? Have you checked evap hoses? Replaced the gas cap?
post #8 of 13 (permalink) Old 05-01-2019, 07:38 PM
Moderator
In some areas you can pass emissions if there are 1 or possibly 2 incomplete IM monitors, but I am not aware of any areas where you can pass the test with a failed IM monitor. An Evap P0442 code = Evap IM monitor failed = failed emissions test.
snosaint likes this.
post #9 of 13 (permalink) Old 05-02-2019, 01:17 PM
Originally Posted by carrzkiss View Post
Hello All;
OK.
The codes are:
P0171 & P0174
Thanks.
Wayne
More than likely, you are looking at the lower intake manifold gaskets, as most Duratcecs as they age, end up giving the P0171 and 174 code when they wear out. I replaced my years ago and it never came back, after making sure it wasnt the PCV hose.
SAAN is offline
post #10 of 13 (permalink) Old 05-02-2019, 01:46 PM Thread Starter
The codes came back.
2001 FORD TAURUS Program Airbag Module (RCM) taurusowner92 Maintenance and Repair 0 06-10-2015 03:56 PM
Check engine light on: P0171 and P0174 codes bitcat70 Maintenance and Repair 15 09-15-2014 02:10 PM
01 taurus p0171 & p0174 problems checked near everything taurus_is_killing_me Maintenance and Repair 12 08-17-2014 10:00 PM
Another P0171 and P0174 Thread Machspeed Maintenance and Repair 8 08-08-2014 11:14 PM
Taurus 2004 P0174 mikedia Maintenance and Repair 2 08-27-2013 12:18 PM
You may post new threads
You may post replies
