How to tell if my 1997 IAC is bad? - Taurus Car Club of America : Ford Taurus Forum
 1Likes
  • 1 Post By Jeff K
post #1 of 9 (permalink) Old 04-17-2019, 08:18 PM Thread Starter
Year: 1997
I have a 97 LX. It got to running real crappy so I installed new plugs and wires, a new PCV valve, replaced the U shaped rubber hose from the PVC to bottom of the intake and the two rubber parts in the line from the air intake tube to the front valve cover. Also cleaned the throttle body (back side of it was dirrrrty), lower intake and secondary valves as good as possible and flushed the upper intake with solvent. The IAC passage was just about totally blocked, now it's not.
The plugs didn't look all that bad, I suspect it was the almost blocked IAC passage was causing the bad idle, just took getting on the gas a little to make it run mostly better.
Problem is now most of the time it wants to idle over 1,000 RPM. City gas mileage is not very good now. Acceleration from stop to 55 is very nice, an I wasn't pushing the pedal close to the floor.
No check engine light, no codes. I had the battery disconnected while doing the work.
I suspect it's an ex-rental fleet car due to it having a 7,000 RPM tach when an LX with DOHC V6 was supposed to have an 8,000 RPM tach. Does have the 120 MPH speedometer. Another "thing that makes me go hmmm" is the PCV tube and hose from the intake duct to the front valve cover is not at all like the photo of the Dorman (or other brands) replacement for that part for a 97. It has a 90 degree rubber elbow at the valve cover and the "why is this here?" 90 degree connection at the intake tube that requires the special shaped hose - when a perpendicular connection and straight hose would have been the logical choice. Dorman's replacement has what looks to be a less than 90 degree valve cover elbow and incldes a plastic tube that's not the same shape, assuming they have the right photo. Why would I want to replace the hard tube when there's nothing wrong with it, and it doesn't include the rubber hose to the intake duct. I've owned and/or worked on a lot of fleet vehicles and most of them have had "This doesn't exist." or "We never made that." combinations of parts which make them difficult to find the correct parts for repairs. (Ask me about a 2004 Dakota with a V8 made *mostly* of early 2003 parts that shouldn't have been in that truck.)
BTW, every time I work on newer cars I wanna swat whomever designs them with the PCV connected to a dry part of the intake. All that does is cause crud buildup. If it was routed to a wet part of the intake, there would be no buildup problems. Even a GOOD vapor/oil separator would help. I've seen ONE car with a factory PCV oil separator, a 1994 Oldsmobile Achieva, but it was a *bad* separator that hardly did anything. It had some filter in it like a chunk of a washable furnace filter. It would get coated with oil then it would go through and grunge up the inside of the intake.
Galane is offline
post #2 of 9 (permalink) Old 04-17-2019, 08:30 PM
Fwiw, your pcv valve sits in an oil separator tube. Did you happen to clean the "c-channel" behind the tb gasket on the face/throat of the uim? It's important to clean this and its 3 notches at the bottom. Also, clean the hole and tunnel in the top left of the "c-channel" as this is the passageway from the egr valve. You can clean the iac with intake, tb or carb cleaner, but keep the elec. end elevated. Don't get that end wet.
post #3 of 9 (permalink) Old 04-18-2019, 02:38 AM Thread Starter
Year: 1997
I flushed all the passages in the upper intake. It wants to idle well over over 1,000 RPM. After letting it sit and warm up sometimes the idle will drop, most of the time it wants to stay high. There's a connection on the back of the upper intake near the throttle body, with two small hard vacuum lines. I had to put a zip tie on it to get it to stay on. I noticed it had fallen off while I was taking the upper intake off.
Galane is offline
post #4 of 9 (permalink) Old 04-18-2019, 10:29 AM
^+1. Those small hard red/green lines supply vacuum to/from the egr, fpr and evr. Green- from evr to egr. Red- to fpr & to evr.
post #5 of 9 (permalink) Old 04-18-2019, 01:57 PM
People say aftermarket PCV valve will screw up the idle on these engines and also vacuum leaks will cause a high idle.
Automender12345 is online now
post #6 of 9 (permalink) Old 04-18-2019, 02:06 PM Thread Starter
Year: 1997
I used a genuine Motorcraft PCV valve.
Galane is offline
post #7 of 9 (permalink) Old 04-18-2019, 03:56 PM
Year: 2000
+1 for possible vacuum problem
ayc80 is offline
post #8 of 9 (permalink) Old 04-27-2019, 04:58 AM Thread Starter
Year: 1997
I replaced the IAC yesterday. Bought a new one off eBay because due to the DOHC V6 being a rare option companies want to really gouge on the price for parts for it (and the V8). Makes me wonder if there's really any difference in the IACs for the three engines other than the connector position.
I started the car and it went up to 1500 RPM for a bit then dropped to 1000, then down a bit more to just under the 1K mark. Call it 900. All good now, right?
Nope. A few hours later I took it for a drive and idle speed was still erratic. Part of the time it would idle correctly, part of the time it wanted to run 1500 with my foot off the gas, despite being warmed up. Once it wanted to "idle" at 2000. But overall less time spent at the wrong RPM. If it was a vacuum leak it ought to run consistently at the wrong idle speed.
Still no check engine light. Seems like it may be the TPS on the way out. Apparently the almost fully clogged IAC passage had been masking problems until the plugs and/or wires got so bad it'd barely run without pressing the gas pedal some. Or possibly the IAC passage had become completely blocked off. It does have almost 110K miles on it.
Galane is offline
post #9 of 9 (permalink) Old 04-27-2019, 01:46 PM
Aftermarket IAC of Motorcraft part? Aftermarket IACs dont work well.
How do I disable 1997 Taurus AC clutch? Galane Maintenance and Repair 9 03-19-2017 11:36 AM
New member looking for resources for work on my 1997 Taurus Pegasus37 Introduction Forum 3 11-13-2015 10:56 AM
1997 SH0 wfs1947 Maintenance and Repair 8 04-22-2014 07:14 AM
Throttle body sensor position 1997 Taurus Flavio Cruz Maintenance and Repair 21 02-21-2014 06:33 PM
What to Grab before Scrapping 1997 Ford Taurus GL Wagon saturninin Taurus and Sable General Discussion 6 12-13-2013 10:37 PM
