Unable to remove belt tensioner - Taurus Car Club of America : Ford Taurus Forum
 6Likes
post #1 of 22 (permalink) Old 04-16-2019, 05:49 PM Thread Starter
I cant get my tensioner to budge. I've twisted two t47 bits. I dont know what to do without removing the ps pump assembly
Audemon is offline
post #2 of 22 (permalink) Old 04-16-2019, 07:09 PM
I use the Torx that are made of a socket and a hardened bit not the one piece kind. Also make sure it is a 47 and not a 50. I can't remember if that is the bolt that a smaller bit fits but a larger one fits better. Can't see how taking the PS bracket off will help.
chartmaker likes this.
post #3 of 22 (permalink) Old 04-16-2019, 09:18 PM
The size progression of Torx makes no logic. Some close together, then a gap. And then there is GM47 which GM sells to services for a huge price. It the same dimensions as T45. Torx is made for the convenience of production lines where they want the screw to stick to the driver and be put in by torque control tools. My best take is to go up the sizes to the one that will not go in, then back down one number.
post #4 of 22 (permalink) Old 04-16-2019, 09:20 PM Thread Starter
That is true, I dont think that will help. I e gone thru 2 socket type t47. It will not budge. I need to get access to the timing cover and that is the only thing in my way to get to ever bolt with ease.
Audemon is offline
post #5 of 22 (permalink) Old 04-16-2019, 09:22 PM Thread Starter
T50 is too big. And a t47 seems to loose. Idk but its proving to be difficult
Audemon is offline
post #6 of 22 (permalink) Old 04-16-2019, 09:25 PM Thread Starter
I have taken everything else off besides the cover/wp assembly.
Audemon is offline
post #7 of 22 (permalink) Old 04-16-2019, 09:32 PM Thread Starter
Should I try heating it up. I mean I've sprayed it with penetrate over 48 hrs ago and nothing.
Audemon is offline
post #8 of 22 (permalink) Old 04-17-2019, 12:22 PM
Year: 2004
I HATE torx bolts! May be advantageous on the production line, but a p.i.t.a. to remove 15-20+ yrs down the road when they are rusty. Wish you luck. Hopefully, you haven't partially stripped out the insides if you've already "twisted" two T47's.
MERCrunner is offline
post #9 of 22 (permalink) Old 04-17-2019, 01:36 PM
Sometimes you need a good tool. There are 6 in the ABS module, two from the top, 2 from the bottom, and two you cannot see from anywhere. Just feel around. Special screws, so never drop one. Rust over the head so hard to get a bit in. Plenty tight at first then too loose for the ratchet to work.
And do that in a JY. Give me a Hex anytime.
post #10 of 22 (permalink) Old 04-17-2019, 02:21 PM
Wack the bolt head with a hammer to help loosen the threads.
2004 Duratec Belt Tensioner replacement rjacket Maintenance and Repair 0 01-29-2019 01:00 AM
my 13 bull has a leaky water pump djcarlos 5th and 6th Gen Engine and Drivetrain 73 07-24-2018 11:03 AM
Bad Belt Tensioner azure Maintenance and Repair 5 09-22-2016 09:18 PM
Serp Belt Tensioner Pulley Replacement Jerseyharold Maintenance and Repair 2 06-15-2014 10:32 PM
Belt Tensioner labtek Maintenance and Repair 8 12-07-2013 02:10 PM
