i Just bought a 1993 Taurus. It is giving me a little trouble - Page 2 - Taurus Car Club of America : Ford Taurus Forum
 7Likes
post #11 of 58 (permalink) Old 04-11-2019, 09:30 PM
You need to look or listen for a vacuum leak that may be causing your stumble. I agree on the Motorcraft brand for newer Taurus but I had good luck with aftermarket IAC valves on my 1991 and 93.
Automender12345 is online now
post #12 of 58 (permalink) Old 04-11-2019, 09:38 PM
^+1. Come to think of it, I used an aftermarket iac on a '94 Vulcan with no issues...
post #13 of 58 (permalink) Old 04-11-2019, 09:40 PM Thread Starter
rickyd123's Avatar
Year: 1993
Yeah the one I got was from a wrecking yard. I'm pretty poor. I don't know what's wrong with it. I can't aford to buy new parts that it doesn't need. I'm going to the wrecking yard tomorrow to get a throttle position sensor.
rickyd123 is offline
post #14 of 58 (permalink) Old 04-11-2019, 09:42 PM Thread Starter
rickyd123's Avatar
Year: 1993
I also looked every where for a vacuum leak and could find one
post #15 of 58 (permalink) Old 04-11-2019, 10:06 PM
Usually the position sensor won't cause that sort of issue. On my 91 it caused a dead spot in the acceleration that was repeatable. You can check it with a ohm meter for smooth change.
post #16 of 58 (permalink) Old 04-12-2019, 06:56 AM
^^^^ +1
Use a DMM in DC Volts hooked to the black and green TPS wires. Turn key to RUN. closed throttle voltage should be under 1.0 V, and should increase linearly (no spikes / dropouts) to 4.5 to 4.8 V at WOT. If it passes this test, TPS is not the issue.
As noted above, I would suspect a vac leak.
post #17 of 58 (permalink) Old 04-12-2019, 08:25 AM Thread Starter
rickyd123's Avatar
Year: 1993
Thanks I'll do that
post #18 of 58 (permalink) Old 04-12-2019, 09:34 AM Thread Starter
rickyd123's Avatar
Year: 1993
This is something I should have added to begin with. About a year ago my car broke down driving down the road. It just died. My aunt put it in the shop. They put a re-manufactured computer in it from China. My aunt drove it about a mile and it died again. The shop put another computer from China in it and it's had the stumble and dying at stops ever since. I got the car from her about a month ago. Does anyone think that maybe China sent a computer for a different model Taurus or maybe it's a bad computer? If so where is the computer located, so I can go to a wrecking yard and get one.
post #19 of 58 (permalink) Old 04-12-2019, 11:19 AM
Could be. Find a used PCM locally or check Ebay. 3 letter/number code (like A9L, A9P, LA3, 8UA etc) on the sticker on a PCM you find must match the code on the current PCM, assuming the correct PCM was installed by the shop.
post #20 of 58 (permalink) Old 04-12-2019, 11:52 AM Thread Starter
rickyd123's Avatar
Year: 1993
can anyone tell me where the pcm is on my 1993 ford taurus
Nice hubcaps for a 1993 Taurus? wrybread Taurus and Sable General Discussion 2 02-21-2019 12:14 PM
2002 Taurus bought Jerry Brown Introduction Forum 1 09-27-2018 10:27 AM
Hi I'm Tom, just bought a 2004 Taurus and already having trouble with the wipers thomasrg Introduction Forum 3 06-29-2015 10:36 AM
Just bought a 2004 Taurus SES jeffersonbb Introduction Forum 4 01-19-2015 11:39 PM
1993 Taurus GL Intermediate Wiper problem theonenandrew Maintenance and Repair 4 04-22-2013 06:50 PM
