Strange A/C Charging Port H Side - Taurus Car Club of America : Ford Taurus Forum
 7Likes
post #1 of 15 (permalink) Old 04-03-2019, 12:28 AM Thread Starter
Draco911's Avatar
Year: 1996
Model: Ford Taurus Wagon
Question Strange A/C Charging Port H Side
Geez, more nutty stuff.
I was trying to get a reading on my A/C Gauge set but the High Pressure Side port has a rubber piece in it acting like a valve but leaking like crazy.
Is this a ford thing? I never seen a R134 quick disconnect internal "valve" like this.
Can I replace it with a standard valved port?
TIA,
Jim
Draco
Draco911 is offline
post #2 of 15 (permalink) Old 04-03-2019, 08:05 AM
Maybe a pic would help. Could be a damaged internal valve or the port cap is broken inside the port.
Draco911 likes this.
post #3 of 15 (permalink) Old 04-03-2019, 08:32 AM
^^^^ +1
I have never had any issues attaching 134a manifold gauges to any of my Fords AC high or low side ports.
Jeff K is online now
post #4 of 15 (permalink) Old 04-03-2019, 09:45 PM Thread Starter
Draco911's Avatar
Year: 1996
Pic attached, weird, right?
Draco
Draco911 is offline
post #5 of 15 (permalink) Old 04-03-2019, 11:45 PM
Year: 2000
I will take a look tomorrow but I don't think the black rubber should be there? There are tools to replace the valve cores without losing your refrigerant, had one for R-12. If it is leaking and you try to pry out the black rubber be careful and wear eye protection. That is the high pressure port and is under a lot more pressure than the low side. I don't know where the black rubber came from, almost like a residual from something?
Scott
boulderdentist is online now
post #6 of 15 (permalink) Old 04-03-2019, 11:51 PM Thread Starter
Draco911's Avatar
Year: 1996
Thumbs up
Scott
Much appreciated. Yeah, I thought it very strange, but no worries, all the gas leaked out due to that rubber piece being there.
Draco
Draco911 is offline
post #7 of 15 (permalink) Old 04-04-2019, 07:05 AM
Never seen a charge / test port that looked anything like that before.
post #8 of 15 (permalink) Old 04-04-2019, 10:34 AM
Could be a DIY repair of a leaking service port with RTV. They put RTV in and screwed cap into place. What is the history of car?. Well valve has to be replaced, they sell AC valve core remover pretty cheap. Also repair kits. It also may be the rubber seal on the valve dissolving.
post #9 of 15 (permalink) Old 04-04-2019, 12:01 PM Thread Starter
Draco911's Avatar
Year: 1996
Thanks again Fellas,
Yeap, will be doing a port swap with new valve. Probably new expansion valve as well as when I tried to charge the system, High Side only went up to 40PSI. Low side was way too high.
TIA,
J
Draco
Draco911 is offline
post #10 of 15 (permalink) Old 04-04-2019, 12:20 PM
Our AC systems dont use an expansion valve, they use an orifice tube.
snosaint and Draco911 like this.
Single port A/C charging 46davis Maintenance and Repair 7 08-13-2018 01:24 PM
Locate HVAC Low Side Port RonT Maintenance and Repair 1 05-19-2018 07:42 AM
1998 Taurus - 12 valve OHV AC low side is low, high side is low fabsroman Maintenance and Repair 2 06-07-2015 09:31 AM
Impossible to connect (ac manifold gauge) to low side port (2004 Taurus) TheEgg Maintenance and Repair 3 07-10-2014 08:33 PM
High Side Port Leaking?? bull geek Maintenance and Repair 13 09-15-2013 10:51 PM
