2006 Taurus (automatic) loses gas and speed gauges while driving... intermittent. - Taurus Car Club of America : Ford Taurus Forum
post #1 of 5 (permalink) Old 03-27-2019, 12:09 PM Thread Starter
I've got a 2006 Taurus with 185K Miles on it. Seems to be running fine, but every so often (and it seems to be associated with rapid acceleration) I will lose my gas and speed gauges, and I will get both a battery indicator light and airbag light on the dashboard. Sometimes it will stay that way for only a minute or so, and then the gauges will come back and those lights will go away. during all of this, the engine remains running, and I am getting no Check engine lights or fault codes.
The car has a new Interstate battery, and also a brand new alternator (both in December). The battery tests fine as of this morning, and last week I had the mechanic who installed the Alternator come check it and it also is still fine. Here are my next troubleshooting steps:
1. Check and re-tighten wiring between the fuse box and the batter (some of the metal cable is exposed)
2. Replace fuses
I've also noticed for the past few months that the shifting is not smooth. The engine will often over rev and then abruptly shift down. I also have had no cruise control for about the past year. Could all these issues be resulting from a bad speed sensor?
Spencer Morgan is offline
post #2 of 5 (permalink) Old 03-27-2019, 01:49 PM
^ Possibly. Is the vehicle ffv?
sheila is online now
post #3 of 5 (permalink) Old 03-27-2019, 03:08 PM
A previous post on the forum had issues with gauges I think when the engine was revved which was found to be a chafed wire in a harness. It either grounded or opened each time the engine was revved. You can start wiggling various wiring harnesses to see if you can duplicate the issue. Most likely try the harnesses that flex between firewall and engine.
Found the thread about the issue. https://www.taurusclub.com/forum/82-...s-strange.html
Final solution from post.
""FIXED---------
It was not the alternator either.
It had a loose connection in the main wiring harness connector at the firewall in the engine compartment.
Every time I would lift up on the harness, just aft of the alternator, the gauges would work correctly. That would also put a little pressure on the contacts in the main engine harness. I was always working alone. I had to remove the gauge cluster and put it on top of the dash so I could see it from the engine compartment.""
Automender12345 is online now
post #4 of 5 (permalink) Old 03-27-2019, 09:22 PM Thread Starter
Not FFV, sorry should have specified.
post #5 of 5 (permalink) Old 03-27-2019, 09:23 PM Thread Starter
""FIXED---------
Thanks! I will give that shot.
