Why is the compressor turned on... - Taurus Car Club of America : Ford Taurus Forum
 1Likes
post #1 of 12 (permalink) Old 12-31-2018, 10:00 AM Thread Starter
While using the heater? Can I disconnect the compressor?
Wrenches is offline
post #2 of 12 (permalink) Old 12-31-2018, 10:33 AM
Manual system of EATC? Compressor runs in all modes (except VENT in the manual system) to dehumidify the air. You can pull the electrical connector off the clutch coil or pull the AC relay in the BJB to stop the compressor from running.
post #3 of 12 (permalink) Old 12-31-2018, 11:36 AM
TollKeeper's Avatar
Model: Mercury Montego
@Jeff K, Thats what I do.. Saves compressor wear, and a bit of fuel mileage
Brian - Carpe Diem
2005 Mercury Montego 52k
2004 GMC Envoy XUV 182k
TollKeeper is offline
post #4 of 12 (permalink) Old 12-31-2018, 11:48 AM
My 05 SEL Premium with EATC has a pushbutton on the ICP to turn off the AC compressor in any mode except defrost. If I didnt have that switch I would pull the AC comp relay in the BJB to disable the comp in the winter months.
post #5 of 12 (permalink) Old 12-31-2018, 12:32 PM
Can you just unplug the switch on the accumulator?
post #6 of 12 (permalink) Old 12-31-2018, 12:40 PM Thread Starter
Thank you very much guys. I couldn't get the clutch plug off because of the power steering pump but I didn't think about the fuse.
You just saved my day.
Got it! Now my belt won't burn up.
Wrenches is offline
post #7 of 12 (permalink) Old 12-31-2018, 01:30 PM
Unless the clutch bearing is shot and not the compressor.
post #8 of 12 (permalink) Old 12-31-2018, 01:56 PM Thread Starter
No, the compressor is froze up.
Wrenches is offline
post #9 of 12 (permalink) Old 01-01-2019, 12:06 AM
Year: 2000
This may be out of date, but there were recommendations to run the AC compressor in the off season, at least a few minutes a month to circulate refrigerant and oil lubrication. Supposedly keeps the "O" rings lubricated and less likely to leak?? I don't know about the newer Fords, but I had an '89 Ranger that eventually required replacement of the majority of "O" rings. Maybe the newer generation of "O" rings are better? My Ranger went to the junk yard with 336,000 miles and an intact and functioning R-12 system. It was so superior in cooling to the R134 of today and I suspect the newer refrigerants of the future.
Scott
Automender12345 likes this.
boulderdentist is offline
post #10 of 12 (permalink) Old 01-02-2019, 07:19 AM
^^^^^ Yup, that is what I try to do on a regular basis. I run it on "warm" winter days, as if the ambient temp is under 35 deg F or so the compressor wont run as the static pressure is too low to trip the CCPS.
