Danged RADIO conked out! - Page 2 - Taurus Car Club of America : Ford Taurus Forum
 5Likes
post #11 of 12 (permalink) Old 09-20-2018, 06:51 PM Thread Starter
Year: 1997
Model: Ford Taurus Wagon
Originally Posted by 46davis View Post
No, not a loose plug, but likely a regulated power supply dying of old age.
The trouble was rather more simple and yet odd: the 15A radio fuse had worked itself loose in the engine bay electrical Power Distribution box.
The fuse had popped out of its slot like a toaster ejects a bread slice. The fuse's feet were sitting loose on the spring terminals so there was only intermittent contact--meaning voltage was correct but amps were low, jumpy, or none at all. That explains all the freakish spontaneous displays and behavior.
I jammed the fuse back down and tapped it snugly into place. Never saw a fuse just work itself loose before. I should have checked that possibility in the first place!
So if anyone's radio has gone suddenly wonky, then dead, check the junction box too!
68Kustom is offline
post #12 of 12 (permalink) Old 09-22-2018, 09:46 AM
That's the first time I've heard of that but it certainly explains the problem. (Apologies to circuit design engineers at whoever made the radio)
Thanks for posting the fix as I'm sure it will save somebody down the road some trouble. 90% of everything is having seen it before.
"There is more on heaven and earth, Horatio, than is dreamt of in your philosophy."
- Shakespeare
68Kustom likes this.
46davis is offline
Ford SYNC2 to SYNC3 Upgrade AdmiralSparklez 5th and 6th Gen Electronics, Security, Audio and Visual 88 04-06-2019 02:03 PM
2003 Wagon Radio Replacement aruption Electronics, Security, Audio and Visual 0 04-25-2018 06:06 AM
Questions about replacing radio. CShaggy Electronics, Security, Audio and Visual 1 08-07-2017 01:30 AM
3rd Gen Radio Troubleshooting Securitygate Electronics, Security, Audio and Visual 4 03-16-2015 10:30 AM
Radio Replacement 98 Ford Taurus Cenzo22 Electronics, Security, Audio and Visual 4 12-18-2013 01:17 PM
