TAURUS code P1504, replaced IACV but still says FAULTY?? - Taurus Car Club of America : Ford Taurus Forum
 11Likes
post #1 of 48 (permalink) Old 09-08-2018, 11:57 PM Thread Starter
Year: 2002
2002 ford Taurus. Engine light came on so I used a code reader which said code P1503(1504 I mean) Idle Air Control Value. Bought one and replaced it but as soon as I re-started the car the code came back and I do not understand this and do not know what to do now.
I am not a mechanic and do not have a bunch of extra money.
I failed an E-Test that was required to take just to get my Tags renewed, otherwise I saw/noticed nothing unusual about how the car was running.
Any help would be so appreciated.
Taurus88K is offline
post #2 of 48 (permalink) Old 09-09-2018, 12:53 AM
Bannerj29's Avatar
Year: 2002
Did you erase the code with the scan tool first? Did you buy A motorcraft part?
sheila, sousa632 and snosaint like this.
Bannerj29 is offline
post #3 of 48 (permalink) Old 09-09-2018, 03:46 AM
Could also be a bad wire or bad connector. If you have a multi meter you can check the resistance of the IAC valve. and compare it to the old one . I should be around 10 ohms but not totally sure on that number but should have some continuity. Motorcrafts IAC seem to be the only ones that actually perform correctly but all should eliminate a circuit code unless it is in the wiring.
Did you erase the code?
post #4 of 48 (permalink) Old 09-09-2018, 10:58 AM Thread Starter
Year: 2002
I cleared the code but it came back. I bought brand name Duralast.
post #5 of 48 (permalink) Old 09-09-2018, 11:01 AM Thread Starter
Year: 2002
Do you mean test the Ohms with the engine off of the IAC or the wire connecting to the IAC or both ?
Yes I erased code but it come back on as soon as I restarted the car with the new IAC from DURALAST installed.
post #6 of 48 (permalink) Old 09-09-2018, 01:31 PM
Most on the forum will say Duralast is junk in terms of responsiveness to engine conditions but it should at least not throw that code. At least on my 2006 Vulcan if you pull the connector off the IAC it will set a code and go to 500 rpms and sit there.
I mean to check the resistance of the coil in the IAC by pulling the connector and measuring at the terminals of the valve. I just went out in the garage and measured a known good IAC and get 11.8 ohms.
kekaye56 likes this.
post #7 of 48 (permalink) Old 09-10-2018, 04:00 PM Thread Starter
Year: 2002
TESTED from 10.8 to 11.3 ohms Also since installing new IAC every engine start it jumps to 2200 rpm then down to 1,000 rpm which it never did before. I'm lost and fear a GIGANTIC mechanic bill coming on.
post #8 of 48 (permalink) Old 09-10-2018, 04:13 PM
That response when you start the engine is almost guaranteed to be from the non Motorcraft IAC. I have had the same experience with after market IAC. The code is a different story and you should take a close look at the connector and wiring to that connector. Maybe wiggle the connector and wiring to see if there is a change in idle. I would reinstall the old Motorcraft IAC and take back the new one. Advance Auto Parts took my valve back after it did not respond correctly. I installed a junk yard one on my 2006, it cost $15.
post #9 of 48 (permalink) Old 09-11-2018, 12:14 PM Thread Starter
Year: 2002
Could it be I have not driven enough Miles after replacing the IAC ? I've used another car and only put under 10 road miles on this Taurus....what do you, or anyone else, think about more road miles for it to retrain/adjust this new IAC?? thanks again
post #10 of 48 (permalink) Old 09-11-2018, 03:32 PM
No the response issue is because it is an aftermarket part. They just don't work well on these Taurus. Code is a wiring issue it seems.
P1633 Error Code 04 Taurus loganlindy Maintenance and Repair 11 03-09-2018 08:52 AM
Back again. 2007 Taurus P0174 code stored, P0171 code pending BullyforMe Maintenance and Repair 6 02-14-2018 09:39 PM
New to me 2007 Taurus with 180,000~ miles on it. I have a P0420 code. BullyforMe Maintenance and Repair 26 07-10-2017 06:47 AM
2007 Ford Taurus Airbag Light Code 19 DuB71 Maintenance and Repair 36 12-07-2014 01:59 PM
2008 Taurus SEL Airbag Code 46 MBeltran 5th and 6th Gen Maintenance and Repair 4 07-06-2013 11:31 AM
