Long Crank - Taurus Car Club of America : Ford Taurus Forum
 2Likes
post #1 of 19 (permalink) Old 05-18-2018, 06:33 PM Thread Starter
dirtcrew51m's Avatar
Year: 2002
Long Crank
02 Taurus 3.0 ohv, Started to take longer to crank the past week, I crank it, try again, it starts, runs good after, heard fuel pressure damper but I cant find one or dont know if it has one, fuel system seems not to hold pressure. Possible fuel pump or stuck open injector? I also smelled a hint of richness from the exhaust upon startup
dirtcrew51m is offline
post #2 of 19 (permalink) Old 05-19-2018, 08:39 AM
repairman54's Avatar
Hot start or cold start?
Long crank hot start could be a leaky injector, holding throttle open while cranking and if it improves is one test as more air is let in to counter act possible flooding from a leaky injector..
Long crank cold start could be low fuel pressure, when was the fuel filter last changed? Multiple key on/off cycles before cranking is one shade tree test to see if cold start improves.
This is assuming motor is in a good state of tune, no codes, etc. .
Fuel pressure readings are needed as I've had warm fuel pumps loose pressure after driving a while.
John
'11 Tahoe
'09 Malilbu LS
'03 Sable LS 24v
'05 Sable 24v son's
'01 FLHR
Ski Doo's Sea Doo
Previously enjoyed vehicles
'07 Mustang GT 3 pedals
'89 S10 Blazer 4x4
'75 Cordoba
'68 GTO
'68 Chrysler Newport 2dr
'67 Chevy Caprice 2dr
'67 Chevelle
'65 Bonneville
'65 Chevelle
'64 Olds Jetstar 88
repairman54 is offline
post #3 of 19 (permalink) Old 05-19-2018, 10:55 AM
Play Nice or Don't Play
jag1959's Avatar
Engine: 3.4L Yamaha V8
What is the ECT reading?
It's SHO time!
jag1959 is offline
post #4 of 19 (permalink) Old 05-19-2018, 07:42 PM Thread Starter
Year: 2002
Cold start, was reading fuel damper leaking back, car dont have one, or cant find one, changing injectors tomorrow, see what happens.
post #5 of 19 (permalink) Old 05-19-2018, 08:47 PM
Might want to do a simple test first. Key on but not to start and you should hear the pump run ~1 second and quit, key off and repeat key on and listen. Do it a third time and start the car. If it starts better you have a bad fuel pump. If it is worse, likely an injector leak, but that is very uncommon. Loss of stored fuel in the supply either, goes to the tank, (common) leaks out injector, (uncommon) or leaks out on the ground.
chartmaker is online now
post #6 of 19 (permalink) Old 05-19-2018, 09:30 PM
Sucking fuel through fuel rail pressure sensor vacuum line?
post #7 of 19 (permalink) Old 05-20-2018, 08:18 AM Thread Starter
Year: 2002
Key on, pump cycles, no sensor on the fuel rail, there is a return on the fuel filter, only one line to the engine, thinking fuel returns through the filter, cant find any diagram for this fuel system, after I change injectors if it still happens fuel pressure might be bleeding back through the pump.
post #8 of 19 (permalink) Old 05-20-2018, 08:31 AM
'02 should have a sensor like the pic on the fuel rail, vac hose and electric to it. If it is actually '01 no sensor but it would have 3 nipple fuel filter with pressure and return to the tank on the back side. The '01 was a one year only 3 nipple filter.
post #9 of 19 (permalink) Old 05-20-2018, 09:13 AM
^^^^ +1
the 01 was a 1 year only fuel system with the 3 port fuel filter. Are you sure it is really an 02 MY?
post #10 of 19 (permalink) Old 05-20-2018, 06:42 PM Thread Starter
Year: 2002
Ya title and vin says 02 but probably 01 leftover, think I fixed it, new injectors, fuel filter and iac, will see tomorrow. Seeing there is no damper or regulator figured was leaky injector.
Consuming Coolant slowly, no leak visible. mrvanwinkles Maintenance and Repair 114 04-12-2019 09:24 AM
Fixed long crank when cold, still have high idle plessm Maintenance and Repair 2 01-17-2017 07:43 PM
Intermittent (now permanent) No Crank, No Start Peter F Maintenance and Repair 3 05-10-2013 11:05 AM
Intermittent Long Crank, Fuel pressure low Blackthorne Maintenance and Repair 5 04-17-2013 10:45 PM
