Power window hard to raise, easy to lower - Taurus Car Club of America : Ford Taurus Forum
post #1 of 4 (permalink) Old 01-28-2018, 05:43 PM Thread Starter
Year: 1999
2002 Windstar van, 87,000 miles. Bought the car recently, driver side front power window was up all the way, wouldn't lower. I had never seen this window go up or down prior to working on it.
Replaced the old window motor with a rebuilt motor from O'Reillys. Now the window goes down enthusiastically, goes up reluctantly. Raises to half close fairly well, has difficulty from half closed to to 80% closed (stops, need to press the close window button again -- sometimes several times), then does better from 80% closed to completely closed.
The inside wall of the door moves in, towards the driver seat, as the window goes up. As the window goes down, the inside wall of the door moves towards the outside wall of the door. It's easy for me to imagine that there is some binding in play here as the window raises -- or maybe this is normal (it's the only door I've watched while the window went up and down)
I'm wondering is the metal parts (thin metal bars that form an X) have maybe warped over the years. Maybe I could push them towards the outside of the door to get them closer to lined up. Or perhaps just replace the entire regulator. Regulator (with motor) is nearly the same price as the motor I just bought. Motor seemed easier to replace, which is why I went with the motor replacement. Bad choice maybe.
I sprayed the tracks with Liquid Wrench silicone spray, and put Sil-Glyde on the large curved metal part with all the teeth. Didn't seem to make any difference.
Never worked on doors before -- Looking for ideas on how to proceed. Labor is free, parts are not.
Earl Tnatza is offline
post #2 of 4 (permalink) Old 01-28-2018, 07:30 PM
I'll Be Watching You!
sousa632's Avatar
Year: 2007
Model: OTHER
Engine: OTHER
Follow this video. It helped with my old 98
John
sousa632 is offline
post #3 of 4 (permalink) Old 01-28-2018, 11:45 PM Thread Starter
Year: 1999
I will certainly give it a go first thing tomorrow. I already have the holes drilled out to get to the little bolts.
I'll look at the voltages as well.
Interesting idea.
post #4 of 4 (permalink) Old 01-29-2018, 09:50 PM Thread Starter
Year: 1999
Voltages check out ok (+/- 12volts).
Adjustments to the little bolts, and prying the motor away from the metal it's bolted to didn't change anything.
Lubricated both sides of the curved metal bar with teeth (no idea what it's called). Had to remove four door rivets to get to the backside of that bar. Must be steel rivets -- a bit hard to drill out. That didn't help either.
One thing did work: I lubed the vertical track in the upper part of the door where the sides of the glass window rub against the rubber/plastic as the window rises. Used Napa's Sil-Glyde Silicone Lube compound. After messing with this window for three days, I'm a bit stunned that it now works.
Probably didn't need to change out the window motor, but I'm ok with having a new motor in there.
Tempted to lube more windows before they need it -- or is that maybe asking for problems?
'02 SE Power Window Wiring Problem Chrisski3 Electronics, Security, Audio and Visual 0 01-04-2015 09:17 PM
Introduction - Also fix for driver side power windows issue Kdig85 Introduction Forum 7 11-07-2014 10:38 AM
Hypertech Vs. SCT: A Review Sam Taurus and Sable General Discussion 2 09-08-2013 11:01 PM
