power steering goes out - Page 2 - Taurus Car Club of America : Ford Taurus Forum
 3Likes
post #11 of 13 (permalink) Old 11-04-2017, 09:33 AM
Originally Posted by sousa632 View Post
Chart's right. That's the only other shield on that side of the engine.
I'd also concerned with the condition of the belt and the tensioner. A little water should not cause that much of an issue unless the belt is stretched or the tensioner is shot as well.
Daughter's '98 DOHC had issue with PS out when she pulled into her drive and water was standing in the low between the road and her driveway. Car did not have a shield. Came that way new. New belt fixed the issue.
My '03 DOHC missing and I have had it 3 1/2 years no issue. Has the Gatorback brand from when they called it that.
Good call on replace the belt and check the tensioner. I am on Bull #7 & #8 and never replaced a tensioner. Several belts as normal maint. Pic of why belts need to be replaced.
Case: Lin Cont new and within warranty PS failing at parking lot speeds. Dealer put everything in PS new and did not help. Belt was bad. Hardened and glazed. It was not the tensioner. Just poor OE part.
Keep it simple.
sousa632 likes this.
post #12 of 13 (permalink) Old 11-04-2017, 11:33 AM Thread Starter
Year: 2000
Engine: 3.5L Cyclone V6
Called many junk yards. Only a few had any Taurus's, most did not know what I was talking about. Went to them but they did not have part on car.
cmac is offline
post #13 of 13 (permalink) Old 11-04-2017, 07:13 PM
I'll Be Watching You!
sousa632's Avatar
Year: 2007
Model: OTHER
Engine: OTHER
In TX don't you have U-Pull-It yards that you can get exactly what you are looking for? Did you check how your belt looks?
John
sousa632 is offline
Random misfire all cylinders (code P0301 thru P0306) + power steering question Billsfan4 Maintenance and Repair 28 10-18-2015 07:54 AM
Power steering pump removal problem oldad Maintenance and Repair 29 03-06-2014 01:08 PM
