Issues with timing. - Page 2 - Taurus Car Club of America : Ford Taurus Forum
 1Likes
post #11 of 18 (permalink) Old 11-02-2017, 07:50 PM
Play Nice or Don't Play
jag1959's Avatar
Engine: 3.4L Yamaha V8
What brand of IAC did you use?
It's SHO time!
jag1959 is offline
post #12 of 18 (permalink) Old 11-03-2017, 08:20 AM Thread Starter
I dont recall. has that been a problem ?
metermike is offline
post #13 of 18 (permalink) Old 11-03-2017, 08:39 AM
Yes, the only IACs that function correctly are the Motorcraft. All other brands are junk, and do not work well, if at all.
post #14 of 18 (permalink) Old 11-03-2017, 11:40 AM Thread Starter
Anyone else have this happen with an off brand IAC ?
post #15 of 18 (permalink) Old 11-03-2017, 12:48 PM
Nearly everyone has minor to major issues with a non Motorcraft IAC.
Search IAC here, and read the hundreds, if not thousands, of posts about idle problems going away when a Motorcraft IAC was used to replace another brand IAC.
post #16 of 18 (permalink) Old 11-03-2017, 03:15 PM
I had a IAC valve on my 2006 that was moaning at cold idle and I decided to cheap out, 40% off, and buy a Advanced Auto store brand, not sure what the brand was. I installed it and instantly noticed idle shot up real high on start up much higher than OEM. Then it did not respond right trying to keep idle. Things really went bad when you put the AC on. It just responded too late and dropped idle then shot idle up after the initial load of the AC. The worst issue was on the highway, it kept feeding air when I left off the gas and car would take longer to slow down forcing me to use more brakes in stop and go traffic. I returned it to AP and went to the Pull a Part and got a used IAC from a 2006 and everything was fixed.
The aftermarket one that I had was just not tune to respond the same as the Motorcraft one.
Automender12345 is online now
post #17 of 18 (permalink) Old 11-03-2017, 07:05 PM
I have JY spare for my DOHC bulls. I cleaned the JY one, oiled it and switched it out, works just fine. I would rather have a used one cleaned than a new one unless it was JY priced. So I have a good spare, proven. Switching one out takes minutes.
chartmaker is online now
post #18 of 18 (permalink) Old 11-04-2017, 08:10 PM Thread Starter
OK, today I switched out the AIC, back to the one I took off. ( I save the old parts in the new part boxes) I didn't do much driving , but monday will tell. Thanks to all for the suggestions. I will post the results.
my 13 bull has a leaky water pump djcarlos 5th and 6th Gen Engine and Drivetrain 73 07-24-2018 11:03 AM
1994 Taurus 3.0 ignition timing - how to check? TechSurfer Maintenance and Repair 5 10-13-2015 06:54 AM
Timing Cover Oil Leak - Essex 3.8 RobertLemke Maintenance and Repair 0 04-11-2015 06:07 AM
Timing cover, 2005, 12 valve engine dmtaurus Maintenance and Repair 6 04-04-2014 01:22 PM
