1996 Taurus Transmission Cooler Lines - Taurus Car Club of America : Ford Taurus Forum
 1Likes
  • 1 Post By Jeff K
post #1 of 7 (permalink) Old 10-27-2017, 05:39 AM Thread Starter
Year: 1996
Hi, new to forum, found some good information on here as a guest!
I'm inheriting a 1996 Taurus, vulcan engine, with what I believe to be a AX4N transmission. One of the cooler lines from the transmission to the radiator is leaking. The car is currently sitting in a gravel floor shed and has been sitting for several years now. The lines has rusted through.
I stuck my phone under the car since I've not been able to get under it yet, and the pictures captured "AX4N Metric" on the pan. Is this then the AX4N and not the AX4S?
Second, the lines. I searched around the internet and found some on the autozone website. The ones that say are for a non-auxiliary cooler transmission also say they are for the AX4S. The one they list for the AX4N (the only one), says it's for an auxiliary cooler...
Any ideas on what I need to get this fixed? I got the car running, but I don't want to try to drive it to my shop (8 miles) without fixing this yet.
Thanks!
rwrightsman is offline
post #2 of 7 (permalink) Old 10-27-2017, 07:40 AM
Cut out the rusted part, and replace with tranny cooler line and hose clamps. Can also completely replace all the metal cooling lines with hose by replacing the fittings in the radiator and tranny with barb fittings from the hardware store.
If it says A4XN, that is what it is. The A4XS pan would likely say AXOD METRIC on it. Can also verify by counting the number of pan bolts. N has 19, X has 17.
post #3 of 7 (permalink) Old 10-27-2017, 11:39 AM
^+1 on tranny hose/barbs/clamps. Have you checked Rockauto online? You can also check the drivers door end sticker under "TR". X= AX4N. L= AX4S.
post #4 of 7 (permalink) Old 10-27-2017, 11:54 AM Thread Starter
Year: 1996
Thanks for the advice. I was thinking that might work, but just wasn't sure.
post #5 of 7 (permalink) Old 10-27-2017, 11:55 AM Thread Starter
Year: 1996
The sticker has been painted over/removed and painted. I did look for it, but no where to be found...
post #6 of 7 (permalink) Old 10-27-2017, 12:07 PM Thread Starter
Year: 1996
Off hand, does anyone know what size hose barbs are needed? I can take one off, but if someone knows off hand, that would be quicker!
Thanks!!!
post #7 of 7 (permalink) Old 10-27-2017, 12:42 PM
May pm member Lgbpop (Frank). Iirc, 5/16 x 3/8?
secondary transmission cooler zogthegreat 5th and 6th Gen Engine and Drivetrain 0 08-02-2016 09:44 PM
2003 Taurus Sedan 3.0 OHC Transmission cbphinney Maintenance and Repair 0 07-27-2016 07:24 PM
Transmission cooler lines Luke Converse Introduction Forum 3 08-25-2015 07:42 PM
00 to 02 Taurus 3.0 DOHC engine and transmission swap jhuggins Engine and Drivetrain 6 11-02-2014 07:28 PM
