Low Oil Pressure ? - Flickering Oil Light at hot idle - Page 3 - Taurus Car Club of America : Ford Taurus Forum
 1Likes
post #21 of 25 (permalink) Old 03-20-2019, 05:40 PM Thread Starter
Year: 2000
Bump / quick update:
2 years later, Oil light on dash, on my 2000 Taurus, starts to come on solid.
Flickers / goes on and off / stays solid ON, sometimes, at ALL RPM. Finally stays on ALWAYS.
I am somewhat concerned - as I MIGHT have some major failure and possibly NO OIL PRESSURE Now.
But I continue to drive short distance back and forth to work, for a few days, till weekend comes.
Car is showing NO abnormal signs or noises and is working fine.
I do NOT believe I have NO OIL PRESSURE. That can not be. That idiot light on the dash is BS-ing me.
So weekend comes, and I finally have the time to pull the Oil Pressure sender, and install the Mechanical Gauge AGAIN.
Real TEST shows I DO have oil pressure. Real guage reads: 40 PSI at idle cold.
So my sensor / Oil Pressure Sender - is likely BAD.
I order and receive new oil pressure sender from local Ford Dealership.
I have not installed it yet. I am still running with a 1/4 NPT pipe thread PLUG there for now .
the old sensor is out. (and I don't give a sht. - because I know I DO have oil pressure - for the moment.)
I will install the new sender when I have the chance.
I may like to test it first on the bench, with a good gauge, and see at exactly what pressure it gives the electrical "GROUND" connection /signal to illuminate the idiot light. Just for my info ...
So I guess my point is:
If you have a flickering or solid oil light - there may be a chance your oil pressure sender is "on it's way out" / or has failed / or will fail completely later.
Sort of a relief. There is a good chance my flickering oil light, when hot and idling in D Drive at the stop light - is / was due to an
old, worn, marginal, malfunctioning - oil pressure sender / sensor - on it's way out.
[ like I did previously - you gotta do an oil pressure test with a real guage - to know the truth. ]
[ At this point, I would seriously like to have a real good quality mechanical oil pressure gauge on my dash - all the times.
But not sure if I will make the effort to try and install one myself on this car at this point. ]
It would be "nice" to be able to view the ACTUAL ACCURATE pressure of oil in my engine at all times - on the dash.
I guess it is nice to dream.
Maybe on my next car. Buy car (or truck) with REAL Gauges. Not warning (aka "idiot") lights.
mrvanwinkles is offline
post #22 of 25 (permalink) Old 03-21-2019, 06:28 AM
repairman54's Avatar
Oil pressure gauges on fords are no different than a idiot light. My '07 mustang GT and every Ford I've had prior the needle never varies with RPM unlike my GM gauges that move with engine temp and RPM. Fords gauge is a idiot light with a needle unless they finally got real on today's gauges.
John
'11 Tahoe
'09 Malilbu LS
'03 Sable LS 24v
'05 Sable 24v son's
'01 FLHR
Ski Doo's Sea Doo
Previously enjoyed vehicles
'07 Mustang GT 3 pedals
'89 S10 Blazer 4x4
'75 Cordoba
'68 GTO
'68 Chrysler Newport 2dr
'67 Chevy Caprice 2dr
'67 Chevelle
'65 Bonneville
'65 Chevelle
'64 Olds Jetstar 88
repairman54 is offline
post #23 of 25 (permalink) Old 03-22-2019, 02:56 PM Thread Starter
Year: 2000
New Pressure Sender installed. Working. comes on at 4.5 PSI
So I have installed the *NEW* Oil Pressure Sender switch today, and had one run, and it seems to be operating fine.
The Oil Light on the dash is off now, and has not flickered yet, when hot idling in Drive at the stop light.
I may have to do more observation in car, maybe after a good highway run, to see if flickering still at times, ever, when hot, idleing, in D Drive, stopped at light.
Before I installed the NEW pressure sender, I tested it on the bench, connecting it with a TEE fitting, to an air pressure source and a really good mechanical gauge, and an electrical meter on the contact.
Dropping the pressure ever so slowly, watching the GOOD / accurate pressure gauge, it gives ground contact / low pressure electrical signal - at between 4 and 5 PSI.
I would say, by my experiment, at 4.5 PSI and below, it gives electrical signal to the light on the dash.
THIS FORD PRESSURE SENDER COMES ON AT 4.5 psi AND BELOW - SEEMS LIKE TO ME. BY ACTUAL TEST ON THE BENCH.
[ If I could have my wish - I would connect a good mechanical gauge like that one I used in my bench test - on the dash, and feed it the pressure sample, with a small copper tube or something, thru the firewall. But I do not think I will go to the trouble to do something like this, on this car. ]
[ ? Install good aftermarket gauges ? I dunno... lotta work. But many do it . ]
At least I have warning again - if / when my oil pressure drops below 4.5 psi.
post #24 of 25 (permalink) Old 05-16-2019, 11:54 AM
Year: 2002
So install an aftermarket oil pressure gauge in a bracket below the dash?
silver007 is offline
post #25 of 25 (permalink) Old 05-16-2019, 01:43 PM
Year: 2017
Engine: 3.5L Cyclone V6
An old time mechanic once told me, "oil pressure does not matter as much as oil flow, no flow no go".
kekaye56 is online now
Oil Pressure Light Flickers On At Idle mdtobe Maintenance and Repair 3 12-29-2016 08:14 PM
Flickering oil pressure light after booster repairing. ragnalamb Maintenance and Repair 0 11-29-2016 12:00 AM
Oil Pressure light flickering after oil change BlueBrick Maintenance and Repair 4 06-17-2015 09:35 PM
Please help with an overheating issue banshee365 Maintenance and Repair 79 08-08-2014 12:14 PM
Can a dirty oil pan screen cause flickering oil light at idle only when warm? DOHC Neufusion Maintenance and Repair 25 12-18-2013 07:33 PM
