Another coolant leak 04 Duratec - thermostat this time - Taurus Car Club of America : Ford Taurus Forum
post #1 of 3 (permalink) Old 05-17-2016, 01:23 AM Thread Starter
Year: 2004
Having replaced the upper radiator hose a couple of weeks ago, I thought my leak was fixed. I only just removed the bottle of distilled water from the trunk!
Today, after extended stop and go driving in hotter weather, a small puddle of coolant appeared after shut down.
The leak is at virtually the same place. After checking my previous work, I discovered the leak was at the point where the thermostat housing meets the lower radiator hose, almost directly below the last leak I just fixed.
I managed to squeeze my hand underneath and could feel some coolant on the spring clamp and maybe some on the thermostat housing at the join.
Looks like I need to replace the o ring and maybe the short hose. I suppose while I'm doing this, I should change the thermostat - it's the original and I'm at 92k miles now.
Questions:
- Rockauto has Stants and Gates. Which would you choose for thermostat and gasket?
- Is this a usual place for a leak? I presume the o ring should fix the problem or can there be a problem with the housing itself?
rjacket is offline
post #2 of 3 (permalink) Old 05-17-2016, 10:05 AM
May inspect the housing carefully for cracks/damage. If not using Motorcraft, either brand should suffice.
post #3 of 3 (permalink) Old 05-17-2016, 03:44 PM Thread Starter
Year: 2004
Would it make sense to back off the bolts and re-torque them?
Could it make things worse?
rjacket is offline
Massive coolant leak mred95 Maintenance and Repair 17 11-13-2015 02:48 PM
Erratic Temp Gauge and Major Coolant Leak onewaylimited Maintenance and Repair 11 12-06-2014 08:05 PM
Usual suspects of coolant leak another_newfie Maintenance and Repair 12 01-25-2014 07:02 PM
coolant, Rad Leak, power steering pump, and more.. oh my.. Mikes Taurus Maintenance and Repair 6 10-06-2013 08:13 AM
coolant leak (video included) peterf1992 Maintenance and Repair 35 04-29-2013 07:16 PM
You may post new threads
You may post replies
