2004 Mercury Sable random misfire - Taurus Car Club of America : Ford Taurus Forum
post #1 of 19 (permalink) Old 09-12-2015, 01:34 PM Thread Starter
I have a 2004 Sable. The other day my car started shaking a lot and the check engine light started flashing. Took it to autozone they said I had a misfire on 6. I switched the coils on 6 and 4 and took it back, the misfire was now on 4. Bought a new coil and replaced the coil on 4. Ran ok for a few miles, then the same problem happened again. Took it back to autozone, now the misfire is still on 4 (the brand new coil). Now the check engine light is steady on and it's running worse than ever. Did they sell me a bad coil? Why else would the misfire haved moved?
Jessesbeck is offline
post #2 of 19 (permalink) Old 09-12-2015, 01:35 PM
Play Nice or Don't Play
jag1959's Avatar
Engine: 3.4L Yamaha V8
The obvious suspect is the new coil. Get the code read
It's SHO time!
jag1959 is offline
post #3 of 19 (permalink) Old 09-12-2015, 01:39 PM Thread Starter
Got the code read. p0304, cylinder 4 misfire. I'm guessing it's the new coil, too. But isn't there a seperate code for a bad coil?
post #4 of 19 (permalink) Old 09-12-2015, 02:41 PM
ice445's Avatar
No. The computer can not determine if the coil is the culprit in most cases.
ice445 is offline
post #5 of 19 (permalink) Old 09-12-2015, 03:01 PM
TaurusSEComfort's Avatar
Year: 2002
When it comes to anything electrical like coils, sensors, etc. I always try to not get it from autozone. They don't have a good reputation. I recommend motorcraft brand for stuff like that
TaurusSEComfort is offline
post #6 of 19 (permalink) Old 09-12-2015, 03:06 PM Thread Starter
Yeah, I just happen to live really close to an Autozone. I'm going to at least try and return the coil since I don't see any reason the new coil would go out when it's in a different cylinder (4) attached to a different wire and plug than the first one that went out (6).
post #7 of 19 (permalink) Old 09-12-2015, 03:19 PM
jag1959's Avatar
A solid CEL is returning a P0304?
It's SHO time!
jag1959 is offline
post #8 of 19 (permalink) Old 09-12-2015, 03:21 PM
^+1. Motorcraft or Borg-Warner (BWD) coils are recommended. BWD available at Advance Auto or O'Reilly. May check/replace spark plug(s) also. Motorcraft or NGK.
sheila is online now
post #9 of 19 (permalink) Old 09-12-2015, 03:23 PM Thread Starter
I should have been more clear, sorry. When I pulled up to Autozone the CEL was not currently flashing or solid. Got it checked, came back 304. When I started the car, the CEL was solid. Are you saying this is probably a whole new code?
post #10 of 19 (permalink) Old 09-12-2015, 05:15 PM
When changing a part or fixing something related to a CEL best clear the codes and watch for a new one or not.
Codes self clear but some take a number of cold starts to clear the code and extinguish the light.
JBMC34ís 2004 Mercury Sable GS JBMC34 Taurus and Sable Project Log 9 10-29-2015 03:16 PM
Misfire Diagnosis Using Mode $06 (Advanced) Sam Maintenance and Repair 14 06-02-2014 12:24 PM
2004 Sable 3.0 DOHC - Misfire - Bad ignition Coil Codes - PCM issues: PLEASE HELP! 2004Sable Maintenance and Repair 5 05-03-2013 01:37 PM
