Oil cooler adapter leaking bad - Taurus Car Club of America : Ford Taurus Forum
post #1 of 15 (permalink) Old 05-07-2015, 07:48 PM Thread Starter
Year: 1997
Engine: 3.4L Yamaha V8
I found a leak from my oil cooler on my sho around the sending unit had a hairline crack and is leaking. I replaced the sending unit and its still leaking. Ford don't make the part and I can find it. any ideas on where?
celebrityfest is offline
post #2 of 15 (permalink) Old 05-08-2015, 08:05 AM
gipsydanger's Avatar
look at the block and see if its cracked
'93 GL 3.0L, BLUE BUCKET O' BOLTS AKA THE BLUE BEAST
rudedog's son R.I.P dad
gipsydanger is offline
post #3 of 15 (permalink) Old 05-08-2015, 10:42 AM
^ May pm member zenriddles and/or loudsho92.
post #4 of 15 (permalink) Old 05-11-2015, 05:19 PM Thread Starter
Year: 1997
Oil filter adapter
I going to fix my gen 3 sho and sell it. I need to find a Oil filter adapter. That was the source of the leak, now it has a hairline crack and needs replacing. Who has a sho motor with extra parts laying around?
moderator edit: This post was created as a separate thread. OP please stop creating new threads when you have outstanding threads on an issue.
post #5 of 15 (permalink) Old 05-11-2015, 06:20 PM
Play Nice or Don't Play
jag1959's Avatar
Per post 3 above and other posts on your several threads you might try a PM to members zenriddles or loudsho92
It's SHO time!
jag1959 is offline
post #6 of 15 (permalink) Old 05-11-2015, 06:57 PM Thread Starter
Year: 1997
thanks
post #7 of 15 (permalink) Old 05-12-2015, 02:11 AM
All I can find is a picture. Is this the part?
Welding is one way to fix it. It might be possible to use epoxy or loctite from the inside.
post #8 of 15 (permalink) Old 05-12-2015, 06:51 AM
zenriddles's Avatar
I have a few with the oil coolers still attached. I saw your pm.
$25.00 plus shipping sound fair?
RICE - ITS WHATS FOR DINNER !
Eric Lehmann
Lots of V8 SHO's
zenriddles is offline
post #9 of 15 (permalink) Old 05-12-2015, 07:35 PM Thread Starter
Year: 1997
got it and yeah.
post #10 of 15 (permalink) Old 05-13-2015, 08:48 PM
zenriddles's Avatar
Adding pic of cooler assembly. Didn't know how to add it to a PM.
Name:	Oil Cooler Assembly.jpg
Eric Lehmann
Lots of V8 SHO's
2008 Taurus tranmission fluid drain w cooler lines geekwithoutacause 5th and 6th Gen Maintenance and Repair 6 04-09-2015 02:22 AM
Power Steering Pump Bleed Adapter M109Dreamer Maintenance and Repair 3 12-05-2014 03:19 PM
98 SE Comfort 24v Tranny cooler Mwc01l88 Maintenance and Repair 1 07-20-2014 09:32 PM
2006 Taurus Transmission Cooler Install Tom S Engine and Drivetrain 35 06-09-2014 10:36 PM
