Easy Way to Lube Door Latch Assembly - Taurus Car Club of America : Ford Taurus Forum
post #1 of 12 (permalink) Old 02-04-2015, 07:33 PM Thread Starter
I had a door latch stick in the recent cold weather. When you went to close the door it bounced on the latch striker rod. To get it to latch again two things are needed. First to get home, pull up on the outside door handle and once up and still holding it up, use a pen or screwdriver and flip the lever down. The door will now latch in place.
Next you need to lube the mechanism, the latch lever and the workings inside the door. The latch lever is easy to lube but the internal mechanism is harder. If you don't want to pull the door panel, I removed the two torx bolts with a T-27 bit. I removed one at a time. I then use some light lube oil in a spray can and used a red tube to spray in each hole. I figured this out after looking at a spare latch mechanism I had and saw where those holes lead too. It seems that you can reach the majority of the internal workings.
ID:	134577   Click image for larger version
ID:	134585   Click image for larger version
ID:	134593   Click image for larger version
post #2 of 12 (permalink) Old 02-04-2015, 09:25 PM
Good info, good pics.
I have used a screw driver to trip the latch closed to keep the interior lights off with the door open. Might try the spary through the screw holes next year.
post #3 of 12 (permalink) Old 02-05-2015, 11:17 AM
^ Works as advertised.
post #4 of 12 (permalink) Old 02-05-2015, 01:35 PM
I'll Be Watching You!
sousa632's Avatar
Year: 2007
Model: OTHER
Engine: OTHER
I just had this happen the other day on the wagon. Warming the car helped release it, however this can be done to prevent it. Good info... adding it to the Topic Finder
John
sousa632 is offline
post #5 of 12 (permalink) Old 02-10-2015, 05:19 PM
mcfarmall's Avatar
Thanks for the info Automender! This has been a frustrating issue for my daughter and son who both drive a '02 and '97 respectively especially with the bitter cold weather we've been experiencing off and on this winter.
Today I took the top 2 screws out one at a time on the '02 and really hosed it down with KROIL and we'll see what happens.
mcfarmall is offline
post #6 of 12 (permalink) Old 02-10-2015, 06:31 PM Thread Starter
You should also put a little lube on the part that flip and catches also, but that is easy to reach.
post #7 of 12 (permalink) Old 02-11-2015, 08:30 AM
I had this too, I need to go back and redo it with grease, but when my door latch did this I didn't remove any screws or anything, but I did use a liberal amount of wd40. I found that when it stuck like that, if I could put some wd40 in the latch, and then use the door lock post(where you can manually lock and unlock your door), if I pushed down/pulled up hard enough to make that go up and down and force the latch to work, I could keep using wd40 in the latch to push the water out, and it would free up. I did this earlier this year maybe and have not had trouble in months. I didn't have to remove screws either. Those latches get annoying when you are running late for work on a cold morning and just want to get in your car and oh wait, you can't get the door to latch. I will say however, on really cold nights, I tend to leave the door unlocked just in case. But we live in a smaller, safer area.
ohio_grad_06 is offline
post #8 of 12 (permalink) Old 02-11-2015, 09:13 AM
Year: 2000
Thank you for the info.
Here is the lesson I have learned.
Do NOT use "White Lithium Grease" or "Spray Silicone Lubricant" on the latch.
So far, I found "PB Penetrating Catalyst" works well for me. But I am not sure whether it is safe on plastic. So you have been warned.
Best
q0987 is offline
post #9 of 12 (permalink) Old 02-11-2015, 01:30 PM
^ PBlaster is rough on plastics/rubber..... Silicone lube or white lithium grease spray is best to use on them.
post #10 of 12 (permalink) Old 02-11-2015, 01:35 PM
So is WD40. I like fluidfilm.
2015 Taurus Limited
3.5L with 6sp Auto
DailyDriver01 is offline
Cheap heater hose assembly replacement options? Infinitrium Maintenance and Repair 30 02-20-2019 07:30 PM
Replacing wheel hub assembly. Press needed? Torque specs? wrexten Maintenance and Repair 8 08-13-2014 12:38 PM
Anatomy of a Strut Assembly...? azure Maintenance and Repair 5 08-08-2014 02:43 PM
Hub Assembly Project Joerules Suspension, Handling and Brakes 3 06-23-2014 04:34 PM
removing Head light assembly nbpt100 Maintenance and Repair 5 10-20-2013 10:28 PM
