2001 Taurus want crank after it gets hot - Taurus Car Club of America : Ford Taurus Forum
post #1 of 32 (permalink) Old 10-17-2014, 11:53 PM Thread Starter
My mom has a 2001 Taurus. She can drive the car less than 5 miles down town and go into store and come back out and it want crank. The car can sit over nite and fire right up. We will try to crank it and the fuel pump doesn't come on. We bought a fuel pump relay and that seemed to help for about a mth and it did it again. Anyone have any suggestions of what we need to look for.
Clambert is offline
post #2 of 32 (permalink) Old 10-18-2014, 12:31 AM
silver_sable's Avatar
a few suggestions of places to start would be TRS, sometimes called the neutral safety switch, ignition switch and clean all your grounds, especially at the starter.
silver_sable is offline
post #3 of 32 (permalink) Old 10-18-2014, 12:50 AM
DSend's Avatar
Have you tried jump starting it? any weird things going on? Do brake lights stay lit after you removed foot? Do they not light up when you DO press the brake pedal?
DSend is offline
post #4 of 32 (permalink) Old 10-18-2014, 09:41 AM Thread Starter
We haven't checked any of these. The only thing I know is the fuel pump want come on when we try to crank it. It can sit over nite and it will fire right up.
Clambert is offline
post #5 of 32 (permalink) Old 10-18-2014, 06:52 PM
Does the selenoid click? That and the starter can fail when hot if it's dirty from oil leaking on it especially on dirt roads, or it's just near the end if it's life.
Make sure your starter and connections are clean and the battery ground to the tranny is good too.
Jerry56 is offline
post #6 of 32 (permalink) Old 10-18-2014, 07:23 PM
Dirty White Bull's Avatar
Follow the diagnostics, other than that, it is playing a guessing game-
https://www.taurusclub.com/forum/82-m...ing-guide.html
Tyson
Dirty White Bull is offline
post #7 of 32 (permalink) Old 10-18-2014, 08:31 PM
Does the car not crank or not start? It seems you are saying different things each time. One time it wont crank they the other time you say the fuel pump is not running and wont start.
post #8 of 32 (permalink) Old 10-18-2014, 09:09 PM
249hp's Avatar
^+1
402 RWHP 910 FT.LBS.
PDR dyno days May 2004.
249hp is offline
post #9 of 32 (permalink) Old 10-18-2014, 10:00 PM
ice445's Avatar
We're not magic, you have to give more details than that.
ice445 is offline
post #10 of 32 (permalink) Old 10-19-2014, 06:57 PM
My bet it is the starter. Had a 56 Olds back in the sixties, when cold cranked right up, when hot it just clicked. My issue was the rebuilt starter was not for a Jetaway transmission, which need a lot more torgue to turn the transmission when it was hot. Also had a 55 Ford when the engine got hot the solenoid on the fender well would just click. New solenoid solved that problem.
jcb986 is offline
2001 Taurus Inner Tie Rod Ends Automender12345 Maintenance and Repair 9 10-28-2014 08:17 PM
2001 Taurus SEL (Duratec) No Crank xxxcellarator Maintenance and Repair 10 09-05-2014 10:22 AM
2001 taurus shuts off while driving baulkin Maintenance and Repair 40 06-02-2014 05:50 PM
Does the 2001 Taurus SE (OHV) have a Fuel Pump Driver Module? oldad Maintenance and Repair 19 05-22-2013 10:05 PM
