1994 Taurus - Purge Valve Solenoid - Taurus Car Club of America : Ford Taurus Forum
post #1 of 8 (permalink) Old 08-28-2014, 07:41 PM Thread Starter
Hello everyone,
The purge valve solenoid seems to have gone bad in my 1994 taurus 3.8. I am getting error codes for the solenoid, and an occasional strong gas odor.
I have two questions... Is it possible to bypass the solenoid on this model somehow, since a new part isn't exactly cheap. And if there is some way to rebuild/repair the solenoid that I have? I have electronics and soldering experience. Just figured I would ask before I proceed.
Thanks!
Wiggleplum is offline
post #2 of 8 (permalink) Old 08-28-2014, 08:01 PM
63.00 ebay usually found new one oem ford for 30 some odd dollars auction number is
231191446185
14sho is offline
post #3 of 8 (permalink) Old 08-28-2014, 08:02 PM Thread Starter
Thanks for the info 14sho. What do you, and whoever else is reading, think of this:
NEW PV777 Vapor Canister Purge Valve Carburetor Bowl Vent Solenoid (Ford Style)
post #4 of 8 (permalink) Old 08-28-2014, 08:08 PM
Those are universal cheapies would not use
14sho is offline
post #5 of 8 (permalink) Old 08-28-2014, 08:35 PM
Do you get this code in KOEO or CEL.? I've gotten this on a KOEO test but solenoid has checked been fine.
galan747 is offline
post #6 of 8 (permalink) Old 08-28-2014, 09:02 PM Thread Starter
I get the code when running the self test using the dashboard lights.
post #7 of 8 (permalink) Old 08-28-2014, 09:11 PM Thread Starter
How do you check? I am guessing you remove it and apply 12V and watch?
post #8 of 8 (permalink) Old 08-28-2014, 09:12 PM
That is the same thing i got when i did a KOEO( Key on engine off) test. Does not cause a CEL on my vehicle. Don't know if it matters too much if the vehicle isn't running. Hasn't been a problem.
galan747 is offline
P1506 codes on 2003 Taurus DOHC macasper Maintenance and Repair 2 12-27-2013 12:29 PM
