Intermittent starting issue, probably entire starting system - Page 3 - Taurus Car Club of America : Ford Taurus Forum
Closed Thread
post #21 of 22 (permalink) Old 12-16-2015, 04:29 PM
One more experience in no crank. This '03 DOHC, sometimes no crank and lights dim, sometime click and no dim, sometimes it cranks fine. Check all connections, swith the relay in the under hood box, no change. Check the wire to the starter and found this stray bolt on top of the starter, touching the wire from the solenoid to the starter. Removed the bolt, no crank, no dim. (I use interior lights to see) Pic of bolt.
JY starter, took it apart and it was clean and brushes fine. Switched it out and works perfect. 2 more years and no issues. The starter I took off was in nice shape inside so I concluded the solenoid was toasted by the short.
And this: I selected the starter at the JY easiest to get: car with radiator removed.
And for what is worth, I replace my batterys every 3 years. Been hurt couple times and wised up. Battery can have a broken internal connection and check OK but sudden fail. If a connection fails, you can 'over voltage' the system and do damage. Been there, new vehicle warrenty.
post #22 of 22 (permalink) Old 12-16-2015, 08:06 PM
Play Nice or Don't Play
jag1959's Avatar
Engine: 3.4L Yamaha V8
This thread never got that far but in the interest of helping anyone viewing it there is this great resource here as well: https://www.taurusclub.com/forum/82-m...ing-guide.html
It's SHO time!
jag1959 is offline
Closed Thread
Hello - cooling system bypass hose issue jts3 Introduction Forum 3 07-04-2014 07:16 PM
Help with Starting issue and Command Start remusgrrrl Maintenance and Repair 3 03-11-2014 10:09 PM
03 Ford Taurus starting issue. ryan05 Maintenance and Repair 15 02-20-2014 08:37 PM
Intermittent starting broke(n) Maintenance and Repair 16 08-07-2013 09:14 PM
Lock-up Solenoid? Must diagnose and fix my AX4N! Trans issue, intermittent 95GL Maintenance and Repair 22 07-16-2013 10:39 PM
