2000 DOHC Thermostat Orientation - Taurus Car Club of America : Ford Taurus Forum
post #1 of 3 (permalink) Old 06-18-2014, 11:18 PM Thread Starter
Trader Score: 7 reviews
On my 2000 DOHC Taurus, I am replacing the thermostat since the car is running about 10-15 degrees cooler than it should.
I would like to make sure I orient the thermostat correctly when I install the replacement. (Motorcraft replacement).
Which way should the air bleeder valve be? Like have it turned so that the ears of the thermostat are in line with the exterior ears for the bolt holes? Remember, on 96-2000 DOHC motors, the thermostat is located just under and forward/next to the AC compressor. It's directly above the subframe. 2 bolts run vertically. The thermostat is installed horizontally, so I'm not sure if it needs to be set in a certain position.
--Nick
bull geek is offline
post #2 of 3 (permalink) Old 06-19-2014, 09:32 AM
Normally the bleeder goes up, lets air through that way, and any steam bubbles. But I never did one on that location.
post #3 of 3 (permalink) Old 06-19-2014, 02:14 PM Thread Starter
Talked to a mechanic today. Location on a clock doesn't matter for bleeder since it's installed horizontally. Just install it.
--Nick
2000 Taurus DOHC V6: Cold-Start Issues mrdeep2001 Maintenance and Repair 17 10-15-2013 06:51 PM
Rebuild AC in 2000 DOHC bull geek Maintenance and Repair 3 09-10-2013 12:12 PM
need help 2000 taurus 3.0 dohc tankdawg699 Maintenance and Repair 1 08-20-2013 12:00 PM
2003 ford taurus 24 DOHC thermostat housing Question tilwedie00 Maintenance and Repair 3 06-06-2013 07:18 PM
