2001 mercury sable cranks but does not start - Taurus Car Club of America : Ford Taurus Forum
post #1 of 11 (permalink) Old 06-08-2014, 11:57 AM Thread Starter
I have a 2001 mercury sable what im getting is its will not start but starts on occasion like today it started fine this morning did errands before work drove it turned it off short period and then started just fine and then drove to work after work it did not want to start tried every thing check engine light is not on and has not come on im am getting stumped i had to leave it in the parking lot at my work so my question is what could make it do this where it starts on occasion and then when sitting for a period of time will not start it cranks but just does not start
not the fuel pump i hear the humming when key is turned right before crank
jmkasperek is offline
post #2 of 11 (permalink) Old 06-08-2014, 12:21 PM
Spend my 02 wisely...
madscientist's Avatar
Just because you hear the pump does not mean it is not the pump or fuel system that is causing your problem. Based on your symptoms, specifically the sporadic nature of the problem and tendency to happen after the car has been left sitting, the fuel pump is most likely the issue if your battery/cranking voltage is good. It could also be an issue with the fuel pressure regulator (which for '01 is a mechanical unit in the trunk) or the fuel filter bypass valve (also a '01 only feature). You need to check the fuel pressure to eliminate fueling as the cause of your problems. It should at least 45 psi but not greater than 65 psi with the key on, engine off.
-Jonathan
madscientist is offline
post #3 of 11 (permalink) Old 06-08-2014, 05:43 PM
Good call.
Added a pic of the one year only filter. I would only use Motorcraft as the fuel pressure is set there. Comes with a bracket. I did not use that. Poped the old one out of it's bracket and the bolt was really rusted in. Put the new filter in the old bracket and put a hose clamp around it.
If you do a filter, put the hair pins in the lines before slipping them on the nipples. Pointer goes "points away" from the filter. Thus the hairpin has a bevel that lets it ratchet on the nipple over the bulge and stay put. Real pain to put the hairpin on after the line is on the nipple, especially a 3-holer.
Best of luck.
chartmaker is online now
post #4 of 11 (permalink) Old 06-14-2014, 10:12 PM Thread Starter
ok this has happened today after sitting all day at the parking lot at work it start just fine but almost home she revved high then low then high again before stalling on the highway and then from there would crank but no start could it be the fuel pump along with a new filter
post #5 of 11 (permalink) Old 06-15-2014, 09:35 AM
Sounds like my grass cutter when it is running out of gas. The only problems I have had with fuel pumps out of five Taurus were 2001s. They use the weird internal pressure recirculation in the fuel tank. Both had pump failures at around 100k miles with random no starts then starts after waiting an hour or so.
post #6 of 11 (permalink) Old 06-15-2014, 10:28 AM
I agree on a failing fuel pump.
post #7 of 11 (permalink) Old 06-18-2014, 07:55 PM
2002 taurus fuel cap light on after changing fuel pump
i ahave a check engine light on and a fuel cap light on after changing fuel pump, does any1 know where i can get a hose diagram of fuel tank, I must have a hose misplaced
dataurusman is offline
post #8 of 11 (permalink) Old 06-18-2014, 07:56 PM
sorry. i mispalced this...new to forum should be under a new question
post #9 of 11 (permalink) Old 06-18-2014, 10:39 PM
Tom S's Avatar
Year: mult
I would more think you have a small leak in the evap system.
Tom S is offline
post #10 of 11 (permalink) Old 06-28-2014, 07:51 PM Thread Starter
ok just a up date and thank you all for your help found out what the problem was bad crankshaft position sensor oh bow what a job it took to just replace that and sense that shes been purring like a kitten
2001 Mercury Sable P1779, P1000, Speedomete​r, Tachometer​ JWalk Engine and Drivetrain 2 02-26-2014 02:14 PM
2001 Mercury Sable P1779, P1000, Speedometer, Tachometer JWalk Maintenance and Repair 3 01-30-2014 04:13 PM
2001 Sable Cranks, but wont start racinem23 Maintenance and Repair 3 08-30-2013 11:15 PM
2001 SES's 1995 Mercury Sable (The Turd - Cutie Pie) 2001 SES Taurus and Sable Project Log 66 07-18-2013 03:05 PM
Why wont my car start? - Comprehensive No-Start Troubleshooting Guide behlinla Maintenance and Repair 1 01-05-2013 11:52 PM
