Exhaust to Cat Converter connection - Taurus Car Club of America : Ford Taurus Forum
post #1 of 24 (permalink) Old 04-29-2014, 03:45 PM Thread Starter
The connection from manifold exhaust and cat converter started to come loose and get noisy. Engine light also came on and test from mechanic indicated it was Catalytic error. (Probably from being loose) He wanted to replace with new for $1200 which I declined. Since then, exhaust came apart in driveway (I tempted fate for too long). I got under and saw that flange from cat side was gone as was the mesh shield and, what looks like a large spring around pipe, is broken. I pushed pipe directly into exhaust pipe and after disconnecting battery to reset errors, engine light is now out and car sounds fine.
Now, I know I can't drive it but what do I need to connect the two back up? Welding is not an option for me but can I attach a short flex pipe with a flange to exhaust and clamp other side to Cat pipe?
Also, clamps/holders are gone and I'm not sure what type or where to attach new ones.
2005 Taurus SE, 3.0L 12 Valve
UncleWylie is offline
post #2 of 24 (permalink) Old 04-29-2014, 07:21 PM
Tom S's Avatar
Year: mult
Hard for me to follow exactly what the options are without some good photos.
Tom S is offline
post #3 of 24 (permalink) Old 04-29-2014, 07:29 PM
br32124's Avatar
A local muffler shop made me the pipe you are tallking about and installed it (with the mesh shield) for $125 Cdn. It was a common job for them. You could start there. They used a stock shield and pipe and then welded the proper size flange to it that bolted right on.
br32124 is offline
post #4 of 24 (permalink) Old 04-29-2014, 09:06 PM
Check on ebay, (Ford Taurus/Mercury Sable Exhaust Flex Pipe w/OE Flange) there is a company that sells a repair kit which I bought for my 2006 two years ago for the same issue. You then buy a stainless band clamp for stepped connections and your set. Your set for less that $40.
post #5 of 24 (permalink) Old 04-30-2014, 01:47 PM
I was told that you can not use a clamp on the converter, or it will fail testing. Is that true?
whynot162 is offline
post #6 of 24 (permalink) Old 04-30-2014, 01:51 PM
BigWorm's Avatar
thats the first time i've heard of it...as long as its on the car and doesn't have any leaks. it doesn't matter if its clamped or welded.
Robbie
1998 street cruiser farmington track champion 1983 Chevrolet Impala
2009 motorcycle farmington track champion 2006 Harley Davidson VROD
2013 Super Comp Championship Crew Chief Manufacturers Cup series 2006 Vrod Destroyer
BigWorm is offline
post #7 of 24 (permalink) Old 04-30-2014, 02:34 PM Thread Starter
That looks like exactly what I need. I'll give it a try.
Thanks
post #8 of 24 (permalink) Old 04-30-2014, 02:38 PM Thread Starter
Band clamp may just do the trick. I'll try it, thanks.
post #9 of 24 (permalink) Old 04-30-2014, 03:17 PM
so the guy at the parts store is full of.... and I can clamp one on. Thanks,
post #10 of 24 (permalink) Old 04-30-2014, 05:47 PM
Dirty White Bull's Avatar
I know that they used to look underneath with a mirror for tampering when doing tailpipe emissions testing here in Ohio, haven't seen them do it on newer OBDII vehicles when they just hook up to the DLC.
Tyson
Dirty White Bull is offline
Line-out Converter 2004SESSport Electronics, Security, Audio and Visual 11 03-07-2014 03:52 PM
Exhaust Hanger help Slydog39 Maintenance and Repair 3 12-09-2013 04:13 PM
Location of Catalytic Converter rwing93 Maintenance and Repair 0 10-29-2013 03:13 PM
Exhaust pipe noise Detech69 Maintenance and Repair 3 08-11-2013 10:51 AM
Need advice on exhaust repair blondechic451 Maintenance and Repair 9 06-18-2013 04:03 PM
