Hi guys this is my first time on here as a member. I have used your repair forums before with great success but cannot find the answer to my question anywhere this time so I thought I would ask.
At some point during a very trying coolant flush and heater core replacement I broke a vacuum line off that comes from the rear of the upper intake. It broke at the other end and I can't seem to find where it broke off. After searching with no results I think it may be under the upper intake. My problem is that with this being a one year only upper intake I can't seem to find a diagram of where this line should go. I am able to remove the upper intake but do not want to if it is not needed. It seems to control idle because with it disconnected it idles very rough while in gear at idle and sometimes at high (50 and up) speeds.
Any help for a frustrated lost newbee ?
Thanks in advance
Thanks in advance
