2007 Taurus SE, Belt Tensioner, 79k miles - Taurus Car Club of America : Ford Taurus Forum
post #1 of 7 (permalink) Old 07-28-2013, 08:31 AM Thread Starter
Ok, so I have an annoying belt squeak. This is a pre-certifed car from Ford so still have some warranty left. Anyway, took it to the service dept. yesterday and they told me I need a new belt, tensioner and idler pulley. Not covered under warranty at a cost of $500. They said the belt was misaligned causing the two other components to go bad. Now, a few months ago, had the same problem and turned out to be the A/C witch was covered under warranty. They replaced the A/C and belt. I mentioned they were the ones that put the belt on and if it was misaligned it was their fault and should do the repairs at their cost. Basically got the S.O.L treatment. I could proably persue this but I was prettyed P.O'ed yesterday, I dont think it would be worth further aggravation.
With that said, this is something I can do my self. But have a couple questions. Anyone know the size of the torx bit for the tensioner? I looked around online and have seen T27 & T47. I probably have one of these sizes. But you know how that goes. LOL...
We dont drive this car a lot, probably dont have more than 300 miles on the belt since it was replaced by the dealer. Do you think it is necessary to put a new belt on?
Thanks for the help,
Patrick
patrickray is offline
post #2 of 7 (permalink) Old 07-28-2013, 09:28 AM
Ace Convoy's Avatar
ugh I just replaced the belt and tensioner on mine. Unfortunately I don't seem to remember the size of bit's I used :/
Ace Convoy is offline
post #3 of 7 (permalink) Old 07-28-2013, 11:45 AM Thread Starter
Well pulled the belt. Everything seems pretty tight except for the water pump. I can wiggle the pulley on there left/right/up/down almost 1/16" if not more. Oh Joy on this repair....
post #4 of 7 (permalink) Old 07-28-2013, 01:59 PM
I replaced the belt & both pulleys on my '06 SEL about 2 months ago. Simple job, took half an hour. Spent more time getting the belt on & off than anything else.
cpusavant is offline
post #5 of 7 (permalink) Old 07-28-2013, 09:28 PM
Its a T47 on my 03 vulcan.
It is on there tight and normal thread, ie righty tighty lefty loosey.
Dont use the factory bolt if you replace it if said replacement comes with its own bolt.
That said, beat the ever loving **** outta the dealer to honor your warranty, call Ford directly if you have to. Call all of them daily.
Work on it as the last resort as it will void any warranty you have left.
scfamily is offline
post #6 of 7 (permalink) Old 07-28-2013, 09:29 PM
Make sure you draw a diagram of the belt before you remove it if it comes to that.
scfamily is offline
post #7 of 7 (permalink) Old 07-28-2013, 09:51 PM
....or check for a belt routing diagram sticker underhood.
sheila is online now
2007 Ford Taurus Airbag Light Code 19 DuB71 Maintenance and Repair 36 12-07-2014 01:59 PM
2002 Taurus with 2007 Taurus parts lworley18 Engine and Drivetrain 34 09-20-2013 06:55 PM
Is taurus 2002 DOHC and 2001 one use the same engine belt? pinseng Maintenance and Repair 1 05-19-2013 01:09 AM
SERPENTINE BELT TENSIONER 5ohMan Maintenance and Repair 2 05-18-2013 12:23 AM
Belt Tensioner Removal Question - 02' Vulcan emtpjimd Maintenance and Repair 1 04-24-2013 12:11 PM
