2000 Taurus Cruise Control - Taurus Car Club of America : Ford Taurus Forum
post #1 of 12 (permalink) Old 07-02-2013, 04:49 PM Thread Starter
The cruise control on my 2000 Taurus has not worked since I've owned that car and it is a nice feature that I would like to get working. When i press the on button on the steering wheel absolutely nothing happens. No cruise light on the dash or anything indicating it is working.
I read some threads and tried pulling out those buttons and cleaning them but that made no difference. The horn works fine. I have done the cruise control self test and it indicated that there was something wrong with the deactivation switch, so I bought a new one and swapped it out, but still a no go. Upon, closer inspection it appears that one of the two wires that attach to the switch has been severed. It appears that for some reason a length of the wire was cut out and it appears to be on purpose (no idea why this would've been done).
See picture below, the two areas circled in red seem as though they should be connected as they are the same color wire. There is not enough slack on either end to simply solder them back together.
Any suggestions on how to fix this are greatly appreciated.
Thanks
pbdyhcky18 is offline
post #2 of 12 (permalink) Old 07-02-2013, 06:33 PM
The wire may have also just broke from fatigue since it's pinched at that point.
The proper way to fix it would be to strip both ends and put in an extra piece of wire. Can you get the wires out from under the black clip?
behlinla is offline
post #3 of 12 (permalink) Old 07-02-2013, 07:59 PM Thread Starter
The black clip actually seems to be some sort of zip tie around the cables. I might be able to cut it, but I'm not sure. Its such a tight and awkward space up there that I know I'm going to have a hard time fixing this.
I am also new to wiring in general, so what type of wire should I get and whats the best method for adding in an extra piece?
post #4 of 12 (permalink) Old 07-02-2013, 08:24 PM
Well, my guess is it will come off somehow without cutting, so you'll have to take a good look at it.
For wire, just get any old kind of wire that's stranded and about 18 gauge or so. Since you're new, you probably just want to get a few crimp-on butt splice connectors and use those. Whatever you do, make sure the wire are secure and out of the way of other stuff in there so they don't get caught or rub on stuff.
behlinla is offline
post #5 of 12 (permalink) Old 07-02-2013, 08:52 PM Thread Starter
Thanks! I will have to give that a try. Toughest part seems to the the confined space and lack of any slack on the wires. I will report back and let you know how it goes.
post #6 of 12 (permalink) Old 07-07-2013, 12:42 PM Thread Starter
Unfortunately, after putting in a new section of cable(which was extremely difficult in that cramped space), the issue still persists. Nothing happens when I hit the "on" button on the steering wheel.
Doing the self test produces three flashes indicating a "deactivator switch is open or circuit defective" Not sure how this can be the case after replacing the switch and repairing the cable.
What else should I be looking at here?
Thanks
post #7 of 12 (permalink) Old 07-07-2013, 01:32 PM
Check the switch to make sure it's actually closed with the brake released. The switch might be adjusted properly.
behlinla is offline
post #8 of 12 (permalink) Old 07-07-2013, 02:32 PM Thread Starter
The switch just has a plunger that is depressed when the brake is engaged. There is no real way to adjust the switch.
post #9 of 12 (permalink) Old 07-07-2013, 02:34 PM
The White Falcon's Avatar
Year: 2010
Engine: 3.5L Cyclone V6
Is it sticking? Even new parts can be bad...
The White Falcon is offline
post #10 of 12 (permalink) Old 07-07-2013, 02:42 PM Thread Starter
Nope, it moves pretty easily in and out when I press it with my finger. I'm thinking that perhaps there is an issue with the wiring in some other place. How would I test this?
2001 Taurus Control Arms and Ball Joints Replacement Experience Automender12345 Maintenance and Repair 24 06-03-2014 09:59 PM
95 cruise control not working nitro Maintenance and Repair 13 06-26-2013 12:31 AM
Cruise control Sable476 Electronics, Security, Audio and Visual 6 04-20-2013 10:47 PM
Cruise control question NyteFire Electronics, Security, Audio and Visual 2 04-16-2013 10:44 AM
2000 ford Taurus v6 check engine/coolent/reverse goes into gear harsh chorba Maintenance and Repair 12 04-05-2013 12:13 AM
You may post new threads
You may post replies
