How high I can lift the car when I only plan to use two jack stands - Page 2 - Taurus Car Club of America : Ford Taurus Forum
post #11 of 18 (permalink) Old 07-30-2012, 09:51 PM
T_swensen's Avatar
Trader Score: 3 reviews
^ +1 on using chocks/blocks, and not working on a car on a scissor jack.
There is a reason that they banned scissor jacks in salvage yards.
T_swensen is offline
post #12 of 18 (permalink) Old 07-30-2012, 10:24 PM
Year: 1996
Model: Mercury Sable Wagon
Ford does not recomend jacking or supporting the car from the subframe. I know many do it anyway. I am sure they have a reason.
I have gotten away from using jack stands and have acquiredd several10x10 (aprox) blocks of wood and sections of 2x6's for stacking. This is similar to what boat yards use when storing boats for the winter. Much more secure and safer. I don't have to worry about the digging into the black top. It also keeps your support rails from getting hacked up from hard steel jack stand saddle.
Good wheel chocks are a must if you go high or will be dealing with stubburn bolt, etc. You can get a good set at Harbor freight for under $10. They always have a discount coupon you can use to get them even cheaper.
AS everyone has said, if you are just working at the wheel you only need to go high enough to get the wheel on and off. You should be able to change everything and bleed it with out crawling under. I you have to adjust the parking brake or replace hard line then you need to get underneath and you will want more room.
nbpt100 is offline
post #13 of 18 (permalink) Old 07-30-2012, 11:44 PM
Shaken but not stirred, if you can support and shake without it falling off Ľou are in the right direction. I use 3 ton stands and support under them. I made some double 3/4 in hardwood plywood turned in both directions and laminated with glue. 18"x18" is stable and strong!!
Use your good sense and just be safe. I use jack stand with jack released enough to sit on the stand. Esay to jack back up and finish the job~
downhill is offline
post #14 of 18 (permalink) Old 07-31-2012, 05:23 AM
I always chock the wheels and after jacking double check it
the_intimidator_02 is offline
post #15 of 18 (permalink) Old 07-31-2012, 05:44 AM
fct
Provided that no drums, bolts, or other parts are seized enough to require enormous forces to get moving and the car is placed on hard, even surface, using the scissor jack alone should be good enough to change safely brake pads, shoes, drums, or rotors since you don't need to get underneath the car. But yes, jack stand will be a little safer.
fct is offline
post #16 of 18 (permalink) Old 07-31-2012, 09:09 AM
Don't Be Stupid
He's not in south central Texas, he's in the northeast, where winter exists ans they use salt to fight winter.
And regardless if he's under the car or not when it falls, if he's sitting next to it and it falls toward him, he will be.
00tec-satx is offline
post #17 of 18 (permalink) Old 08-02-2012, 01:01 PM Thread Starter
Year: 2000
Q1>
which one set do you buy? rubber or plastic?
Wheel Chock - Harbor Freight Tools
Q2> Next time, when you lift your car up with wood stacks, may you show us a picture so that I can learn from you
thank you
q0987 is offline
post #18 of 18 (permalink) Old 08-02-2012, 10:32 PM
Year: 1996
Originally Posted by q0987 View Post
Q1>
thank you
I like the rubber ones.
I will take a pic but it may be a few weeks.
If you live near a boat yard just look at how they store the boats in dry dock. it is the same thing and the base blocks are similar.
nbpt100 is offline
You may post new threads
You may post replies
