2002 Taurus Duratec CEL flashing - Page 2 - Taurus Car Club of America : Ford Taurus Forum
post #11 of 16 (permalink) Old 07-31-2012, 04:20 PM
Also look for UIM to LIM gasket leak or LIM to head gasket leak (vac leaks).
Jeff K is online now
post #12 of 16 (permalink) Old 08-02-2012, 12:23 PM Thread Starter
I got a BWD Coil pack - (Borg Warner?) - inside the old Motorcraft coil pack, the rubbery filler had baked hard and was cracked - I took off the cowl on the passenger side to get access - much easier than removing the upper intake manifold.
joshaughne is offline
post #13 of 16 (permalink) Old 08-02-2012, 12:47 PM
Yes, BWD= Borg-Warner.
post #14 of 16 (permalink) Old 08-03-2012, 07:53 PM Thread Starter
I used a "BWD" coil pack. Is that made by Borg-Warner? Replacing the coil pack has made the car run much smoother, but the P0301 code still comes up. It seems to be missing when it's cold and then after 1-2 minutes it smooths out, The garage I took it to said they think it's a bad injector on cylinder #1. I'm checking it next.
post #15 of 16 (permalink) Old 08-03-2012, 07:57 PM Thread Starter
Sheila - sorry, I didn't see you answer before I put up that last post.Thanks for your help.
post #16 of 16 (permalink) Old 08-03-2012, 08:01 PM Thread Starter
Jeff K - I got a gasket set for the upper and lower manifolds - will check for leaks when I go into the injectors. I had the UIM off before and the gaskets were oily and kept slipping out of the grooves - should have replaced them at the time. Thanks again for your help.
