Rough idle - Page 6 - Taurus Car Club of America : Ford Taurus Forum
 4Likes
post #51 of 58 (permalink) Old 01-13-2019, 02:43 PM
Exalted Grand Poobah
Lgbpop's Avatar
Year: 1990
Originally Posted by Junglecaddy View Post
I have had all the symptoms mentioned on this page. Erratic and hunting idle. Misfiring. Popping in intake tube like popcorn being made. Fluctuating headlights in idle. Sometimes have to start car second time. Idle not coming down properly or taking a long time to come down. Spent hours trying things checking connections and hoses. Nothing found. Ford had it twice in the 3 years we have been having this issue. Also had the bank 1 Autolite platinum spark plugs burned down to the ceramic in less than 2 years! Cant believe the girl was still running with the massive plug gap. Bank 1 plugs were normal looking.
Well folks after 3 years of replacing IAC, IAT, Engine temp sensor, timing chain, plugs, different gaps, coil, wires, blah blah blah and many hours hunting online for an answer I finally found it.
ALTERNATOR!
The alternator is regulated by the PCM Module hence the 3 wire connector. When the board or diodes go defective in the alternator, the PCM gets a noisy feedback and it does not behave properly and does not control the motor properly. Computers do not like noise or bad signal with AC waveform. SIMPLE TEST was to unplug the alternator while running and see if the engine runs normal again. For me, as soon as I unplugged the alternator, all the symptoms mentioned above instantly went away. Idle came down more. It smoothed right out. Popping in intake (more noticeable when you undo the air filter connection) completely stopped. I purchased new alternator and installed it. Completely discharged the computer for a few hours to make it a clean start and everything is working awesome.
Better vacuum, better braking, lower idle, more control on slippery ground (I am in Canada in rural area) and wife says it has more pickup, smoother shifting and requires much less pedal so way better driveability. Got a kiss for fixing it too LOL
Hope some of you can benefit from this. Love the Taurus!!!
2006 Taurus OHV Vulcan 3 litre. 248,000 kilometres (150,000 miles) on this girl.
Happy to hear you finally sussed the cause of the glitches! What turned you onto the alternator as the cause?
With 150K miles, you're just getting the car broken in. Sorry to hear you went the "toss parts at it" route to figure it out, but on the bright side - you needn't worry about doing them again for a good long time. Now, you can enjoy it for a good while!
Junglecaddy likes this.
2016 Q1 Car of the Quarter
Lgbpop is offline
post #52 of 58 (permalink) Old 01-13-2019, 03:23 PM
ALTERNATOR!
My 2006 had the same exact issues. Moaning and popping in intake was fixed with a new Motorcraft IAC valve. All weird idle response issues usually can be contributed to aftermarket IAC valve. I swap it with my other Taurus and symptoms move to that car. Blinking lights were were solved by replacing worn slip rings and brushes on the alternator at 146k miles
post #53 of 58 (permalink) Old 01-13-2019, 05:59 PM
ALTERNATOR!
"The alternator is regulated by the PCM Module hence the 3 wire connector"
As far as I know, all G1-G4 Bulls have Alt use 3 wire to the reg. Pre '02 use the center wire as the idiot light signal. '02 and later use the same center wire for the PCM signal to the Alt. Very confusing as the regulator color for MC part is the indication of which system is in use. Same physical connection including the V-8's with 2 wire to the Alt but 3 wire connection.
Part # table attached. Several here have had a mixup with the wrong Alt and is a pain. Been there.
Automender12345 likes this.
post #54 of 58 (permalink) Old 01-14-2019, 12:37 AM
Jim Beckett's Avatar
Year: 2004
The alternator on my bull gave up the ghost last week... I think it runs better now (ran pretty good before), AND I'm getting at least 1 mpg better to boot.
It almost made a quarter of a million miles. (Less than 1500 mi to go.)
I'm that guy. Don't be that guy.
Jim Beckett is offline
post #55 of 58 (permalink) Old 01-16-2019, 08:25 PM
Junglecaddy's Avatar
I had the original OEM alternator. I purchased a Bosch replacement (lifetime) and it worked like a charm
Junglecaddy is offline
post #56 of 58 (permalink) Old 01-16-2019, 08:27 PM
We hope to exceed 250.000 mi now that I have fixed the stupid timing chain coolant leak and put a new chain on the girl.
Purrs like a kitten in idle.
post #57 of 58 (permalink) Old 01-16-2019, 08:35 PM
I wasn't throwing parts at it. Originally didn't have the popping. Took to Ford and no problem found. Fluctuating idle was first symptom so started with IAC. Was factory original and felt it was due at almost 100,000 mile. Been doing a lot of work. Cant return and had no improvement. Then went coil cause no vacuum leak found and hoses all great. Finally found a link on the web where a fellow took this to a new level and was measuring voltages at different points on the harness and found discrepancies. Should have all been the same output voltage. He eventually changed alternator. It took me countless hours to find this fix and since it was so easy to test, I disconnected the alternator and voila. All symptoms went away. Tried twice more at different times, for longer periods and same results. New alternator and love the idle now.
post #58 of 58 (permalink) Old 01-18-2019, 08:23 PM
Somewhere there is a bulletin about the defective Alt causing erratic behavior. I had an issue and popped the belt off and it made no difference. I used an inductive timing light and looked at the hex on the crank. Clearly the timing was bouncing all around. Switched to different front plug wire and same issue. I took mine to Ford shop and they found carbon tracking on 2 plug wires. Tec told me not uncommon for that and other things causing problems with PCM signals. Usual issue with the Alt being noisy electric signal is a shorted/open diode. That makes them whine at idle.
