Parking Brake Light On - Page 2 - Taurus Car Club of America : Ford Taurus Forum
post #11 of 13 (permalink) Old 01-13-2009, 12:29 PM
ricer333's Avatar
i just re-read through this post. I noticed that you have Rear Discs... sorry about not reading before so....
There is either a leak in the line or in the caliper. If there is one in the line you should see moisture around the area of the steel line. If you want to test your calipers, I know they make a pressure plate for testing Caliper pressure. I would take a look into purchasing or even renting one of these tools to figure out if it is one side versus the other or even both sides that are weak.
Brake Pressuer Testing
If you want to skip this, it sounds like the other thing you have left is either a bad Master Cylinder (not putting out the right amount of fluid to the rear brakes) or bad rear Calipers.
That's the only 2 things I can think of right now, minus no leaks in the lines.
ricer333 is offline
post #12 of 13 (permalink) Old 01-14-2009, 08:43 PM Thread Starter
Send a message via MSN to sprint45_45
It is probably a leak, i can't check myself because i don't have a garage and it is the middle of winter.(lots of snow and cold). I also wouldn't be able to repair it myself.
sprint45_45 is offline
post #13 of 13 (permalink) Old 01-14-2009, 08:58 PM
mmmfloorpie's Avatar
[/quote]
That's why I'm getting a coolant flush from the dealer! Too damn cold to do it myself.
mmmfloorpie is offline
