Dead Battery - Page 2 - Taurus Car Club of America : Ford Taurus Forum
post #11 of 19 (permalink) Old 12-17-2008, 10:07 AM
Year: 94
Engine: 3.8L Essex
Sure the meter is hooked up right? I have never seen a draw less than about 20 to 50 mA on a modern car after all the modules have gone to sleep.
This question, along with your unusually low posted parasitic drain current readings has also caused me to wonder if your meter settings, or lead connections to measure current are in question.
Don't know what brand multimeter your using, but most multimeters have test lead plug-in jacks to enable the meter to measure large currents, on the level of about 10 AMPS.
So if your test leads were thus connected, your readings might really be .15 amps, or 150 ma & that would be more in line with whats expected.
Now if that level of parasitic drain continued, it could draw a battery down.
Yet more thoughts for pondering.
94 Taurus GL 3.8L PEP204A
Payload & Tow Pkg
pawpaw is offline
post #12 of 19 (permalink) Old 12-17-2008, 11:37 AM Thread Starter
<div class='quotemain'>
After work I will recheck. Something I just remembered that may have something to do with my problem. A couple of months ago the day time running lights quit working right, they were real dim and the bright light light on the dash stayed on all the time even when the car was off, it went out only when you turned on the lights. After asking around I was told to just pull the fuse, so I did and the light went out on the dash and the DRL do not work at all.(Which is fine with me). Again I do thank all of you who are trying to help me. Glad I found this site.
JacksonJW is offline
post #13 of 19 (permalink) Old 12-17-2008, 05:15 PM
Year: 94
Engine: 3.8L Essex
OK, good feedback about the DRL's acting out.
If the fuse to it is still pulled & the battery drain has stopped, then the DRL control module belongs on your suspect list imo.
Payload & Tow Pkg
pawpaw is offline
post #14 of 19 (permalink) Old 12-17-2008, 07:59 PM Thread Starter
Even with the fuse pulled the battery still goes dead after setting more than a day.
post #15 of 19 (permalink) Old 12-17-2008, 10:29 PM
Since you have had a past problem with the lighting in the past, I would disconnect the wiring to the headlight switch and see if the battery goes dead. If it doesn't, then you likely have a shorted headlight switch, which is a fairly common problem.
leftyizme is offline
post #16 of 19 (permalink) Old 12-20-2008, 02:10 AM
Have you tried taking it to Autozone for a battery system check? How old is the battery anyway? They're not really designed for deep discharges like what's happening now. It's the quickest way to kill a battery. Usually they're not really meant to go below 75%-80% of maximum charge.
2001 Taurus SEL
24V DOHC
henrysel is offline
post #17 of 19 (permalink) Old 12-20-2008, 04:38 PM Thread Starter
I purchased the battery appx. 1 year ago.
The headlights turn on and off just fine, I would have to believe that if the switch was shorted the headlights would not work properly. It is the daytime running lights that I have a problem with.
post #18 of 19 (permalink) Old 12-20-2008, 06:13 PM
So what is the actual amperage draw when the car is sitting?
post #19 of 19 (permalink) Old 12-29-2008, 05:33 PM Thread Starter
Sorry it's been so long. I have narrowed it down to the wiper/vap fuse. What is vap?
