Power Steering Fluid Filter - Page 3 - Taurus Car Club of America : Ford Taurus Forum
 1Likes
post #21 of 28 (permalink) Old 06-29-2016, 02:46 AM Thread Starter
Year: 94
Engine: 3.8L Essex
Bump:
Well here it is 2016 & the 94 Taurus & 99 Ranger power steering systems are still doing fine, no return of off center loss of boost, or shudder on either vehicle After installing a Magnefine inline filter in their power steering return line 8 years ago.
It's time to replace them & when I do I'll open them up & post photos of anything the filter media, or magnet has captured. The fluid in both systems is still clear red.
94 Taurus GL 3.8L PEP204A
Payload & Tow Pkg
pawpaw is offline
post #22 of 28 (permalink) Old 06-29-2016, 08:18 AM
Originally Posted by pawpaw View Post
Bump:
Well here it is 2016 & the 94 Taurus & 99 Ranger power steering systems are still doing fine, no return of off center loss of boost, or shudder on either vehicle After installing a Magnefine inline filter in their power steering return line. It's time to replace them & when I do I'll open them up & post photos of anything the filter media, or magnet has captured. The fluid in both systems is still clear red.
I suck out the fluid from the resivor each fall and replace it. Takes maybe a pint. Stays clean, never had a PS issue: 8 Bulls, 5 Lin Cont.
Well, not never, had a seal leak on '01 and put a new shaft seal in. Car sold. = '01 DOHC. 131K
post #23 of 28 (permalink) Old 10-10-2016, 01:32 AM
What is this cylinder? Is this a power steering filter, too?
thecraze is offline
post #24 of 28 (permalink) Old 10-14-2016, 12:21 PM Thread Starter
Year: 94
Engine: 3.8L Essex
Look on page 2, post 18 of this thread, for the factory power steering filter location & what it & the Magnefine filters look like.
Payload & Tow Pkg
pawpaw is offline
post #25 of 28 (permalink) Old 10-14-2016, 02:29 PM
Year: 2004
Don't forget to inspect and clean the mesh "filter" screen at the bottom of the reservoir.
2004 Taurus SES Duratec 107k
rjacket is offline
post #26 of 28 (permalink) Old 10-17-2016, 10:09 AM
Year: 2000
I used a ps filter from autozone after my ps pump started to make a noise and it works good.
rwik is offline
post #27 of 28 (permalink) Old 02-07-2018, 12:41 AM
Year: 1989
Did you figure it out?
Post 18 does not include the answer. That black cylinder shape thing is at the high presure line, not the return line.
renguomin is offline
post #28 of 28 (permalink) Old 01-24-2019, 11:36 PM Thread Starter
Year: 94
Engine: 3.8L Essex
BUMP: !0th year Update!!!
!0 years & 5 months ago I cleaned/flushed the 94 Taurus & 99 Ranger power steering systems with Sea Foam Trans Tune, the specified licensed fluids & added a Magnefine inline fluid filter to the low pressure/return lines after the fluid cooler, to see if it would make any positive difference in the intermittent returning loss of boost & or off center shudder both systems developed, even though both were getting a Full system fluid flush every 30K miles when the tranny in both vehicles got their pan drop, filter change & full fluid pump outs & in spite of the fluid maintenance Both power steering systems developed the same problems.
As reported over the years, after the Trans Tune flush, filling with the specified fluids licensed to meet Fords specifications & adding the Magnefine inline filter back in 08, both systems have remained trouble free for 10 years & 5 months now. Both pumps remain quiet. The Taurus pump Really got quiet after its service in 08 & remains so. The Ranger pump never has been noisy like the Taurus pump got, but as mentioned it too developed the intermittent loss of boost & off center shudder but hasn't returned after adding the inline Magnefine filter.
Magnefine has moved their manufacturing to the USA & now has a Metal body filter housing, so I'm about to change both filters to the new design, as both are 10 years old & close to 30K miles on them, so time for a change.
As mentioned a couple of years ago I'll open both filters & inspect the media & magnet for debris to see if anything obvious turns up & will post some pictures on this thread as a update for the record.
Right now I have no idea why adding the filter seems to have fixed the problem, as both systems fluids looked & smelled fine & easily passed the poor mans blotter spot tests at 30K flush intervals. So we shall see if the filter media, or magnet reveal any suspects they've captured.
Payload & Tow Pkg
pawpaw is offline
