Transmission Cooler Install - Page 13 - Taurus Car Club of America : Ford Taurus Forum
post #121 of 126 (permalink) Old 03-20-2009, 02:42 PM
herrhaus's Avatar
You are a good man Dan. Thanks.
- Leather, Spoiler,
for ATF temperature monitoring. Powered by
___________________
"I was passed by a Taurus once. I just don't understand.............I was pedaling really fast!!"
herrhaus is offline
post #122 of 126 (permalink) Old 03-20-2009, 02:56 PM
silvapain's Avatar
Shh... I don't want that getting out and ruining my rep.
I should add that it's easier if you keep the black plastic air dam on the underside of the bumper cover with the cover; unbolt it from the radiator support instead. It's held on with 3 8mm bolts. I also don't disconnect the headlight wires from the bulbs; I just unbolt the housings and set them up on the radiator header panel still wired up.
- Daniel
Current:
Past:
1997 V8 SHO Silver Frost -
1997 V8 SHO Ebony Satin -
1997 Vulcan GL -
1990 Vulcan Sable -
silvapain is offline
post #123 of 126 (permalink) Old 03-20-2009, 03:01 PM
herrhaus's Avatar
I'm changing the ATF tomorrow (no cooler install.......yet). I was going to pull the splash guard under there....any tricks I should know about? (I haven't had a good look at it yet).
- Leather, Spoiler,
___________________
herrhaus is offline
post #124 of 126 (permalink) Old 03-20-2009, 04:08 PM
2000sable's Avatar
When I pulled the inner fender well sheets I stripped the plastic clips/rivets on them.
Dan suggests not doing a lot of the things I did. Having never done it before... I didn't know and just romoved pretty much everything.
Good luck.
Her name is Laura.
2000sable is offline
post #125 of 126 (permalink) Old 03-20-2009, 05:25 PM
herrhaus's Avatar
I'll figure it out.
Well 2000SABLE, at least your honest about yourself there......I think your little title under your avatar says it all. Hey, why don't you post in that other thread where I was asking for ATF temps. Let me know whether or not you have a a temp gauge.
https://taurusclub.com/forum/index.php?show...mp;hl=ATF+temps
- Leather, Spoiler,
___________________
herrhaus is offline
post #126 of 126 (permalink) Old 03-25-2012, 01:52 PM
tag for later reading
Benzin Bruder is offline
