PRESALE: Adam's Deep Wheel Cleaner!!! - Taurus Car Club of America : Ford Taurus Forum
post #1 of 9 (permalink) Old 02-27-2013, 07:00 PM Thread Starter
A SPECIAL PREORDER OFFER FOR OUR FORUM MEMBERS
Adam's Deep Wheel Cleaner is probably one of our most anticipated launches this year,
so we wanted to give our loyal forum customers the first chance to jump on it!
All orders that include Deep Wheel Cleaner or the New Trim & Lug Nut Brush begin shipping by Monday March 4th.
As a PreOrder Special Bonus - Use the code PRESALE2 to take 10% off your order
Plus get $5 flat rate shipping anywhere in the continental US
And orders of $50 or more will receive TWO FREE Edgeless Utility Towels!
NEW Deep Wheel Cleaner Special Introductory Price! (click the image to order)
Adam's Deep Wheel Cleaner is the ultimate way to remove stubborn brake dust and metallic contamination from your wheels. The thick formula clings to wheel surfaces and allows the european derived formula to melt away the stubborn brake dust commonly left behind by many of todays high-performance braking systems. The color changing formula lets you know its working, turning to a deep purple as it activates and does the hard work for you.
Best of all Adam's Deep Wheel Cleaner is safe for all wheel finishes. So whether you have factory clear coated wheels, aluminum, powder coat, or paint the highly effective cleaning solution will remove the stubborn brake dust, but will never harm your wheels. Saturate the wheel with Adam's Deep Wheel Cleaner, allow the color changing effect to activate, then agitate with an Adam's Boulder Blonde Wheel Brush. Rinse away the residues to reveal a deeply cleaned wheel.
With active cleaning agents and advanced surfactants the formula is perfect for cleaning away the worst, most baked on brake dust commonly found in the barrel of your wheels. Simply spray on, allow the cleaner to activate, and then agitate using one of Adam's Turbo Sticks or Wheel Woolie Wheel Cleaning tools (sold separately).
Adam's Deep Wheel Cleaner is great for more than just wheels too! Have a light colored paint job like white or silver? Then you've no doubt noticed the little orange iron particles that stick to your paint. Adam's Deep Wheel Cleaner can be sprayed on these little trouble areas and used to dissolve the iron from these surfaces as well.
Adam's Deep Wheel Cleaner is guaranteed to be the best wheel cleaner you've ever experienced!
NEW & IMPROVED TRIM & LUG NUT BRUSH (click the image to order)
Sometimes the right tool for the job makes all the difference, and this is a tool you'll need to get the job done right. Use it with soap and water to clean around badges, inside door jambs, under the hood, your lug nut holes, or even your brake calipers. It's a versatile tool backed with the Adam's 110% money back guarantee!
Our newest Trim & Lug Nut Brush uses the same super soft boars hair as our previous brush, but now set in a completely metal free design with a longer tapered handle thats more comfortable and more durable than our previous version. It works amazing with our NEW Deep Wheel Cleaner to get that hard to clean brake dust out of the hard to reach areas.
To ensure it withstands years of use with cleaning products and water the bristles are set in a completely chemical resistant epoxy, secure set in a the tapered plastic handle, the top of the brush head is then cut to a slight curve to allow easier access into tight spaces around lugs nuts and other wheel crevices.
The 7.5" long handle makes this brush extremely comfortable to work with and the 2.5" long bristles make this the ideal tool to clean away without ever scratching delicate surfaces. When its not cleaning wheels the Adam's Trim & Lug Nut Brush is the ideal way to clean around badges and emblems. Simply dunk in your wash bucket or spray a liberal amount of Detail Spray into the area to clean and gently agitate the area.
Adam's Trim & Lug Nut Brush has great uses around the interior of your car as well. Use it to clean around radio control knobs, door switches, or anywhere those tiny bits of dust and crumbs want to hide. You'll find dozens of uses for this effective cleaning tool all over your car that will not only make your detailing easier and more effective, but more enjoyable too.
CHECK OUT OUR CLEANER & BRUSH COMBO, DEEP CLEAN TIRE & WHEEL KIT,
or DELUXE DEEP CLEAN TIRE & WHEEL KIT FOR EVEN BIGGER SAVINGS!
For More on The NEW Deep Wheel Cleaner or NEW Trim & Lug Nut Brush watch our latest video
Owner & Master Detailer of Insane Paint Auto Detailing ~ Birmingham, AL
Garage Queen - '06 SRT426 Charger: Modified beyond belief, the right way, by the right builders
Wife's - 2013 SHO: A couple things done
Shop Truck - 2013 F150: "Root Beer"
Adam's Polishes Product Representative
post #2 of 9 (permalink) Old 02-27-2013, 07:27 PM
Does it contain hydrofluoric acid or any other strong acids? Or is it an alkaline solution?
behlinla is offline
post #3 of 9 (permalink) Old 02-27-2013, 11:12 PM Thread Starter
I'm sure it's not acidic. Otherwise we wouldn't say it'd be safe for paint finishes. Not sure about the alkaline solution?
post #4 of 9 (permalink) Old 02-28-2013, 12:30 AM
Alkaline/basic/caustic (high pH) is the opposite of acidic (low pH), so if it's not acidic it's probably alkaline unless the pH is neutral (7). The fact that it changes color tells me there's probably some kind of pH change going on there. I think brake dust is acidic due to the adhesive residue it contains, so it would make sense for the cleaner to be slightly alkaline. When they meet the reaction would reduce the pH and the color would change due to the pH indicator? in the solution.
I could be wrong but just curious.
EDIT: I went to your website and it says "pH neutral" so I guess that answers it.
behlinla is offline
post #5 of 9 (permalink) Old 02-28-2013, 09:25 PM Thread Starter
Lol. GOTCHA!!!
Bump!
post #6 of 9 (permalink) Old 03-01-2013, 10:23 PM Thread Starter
Flip to post #133
PRESALE: Adam's Deep Wheel Cleaner & NEW Lug Nut Brush - Adam's Polishes Forums
post #7 of 9 (permalink) Old 03-05-2013, 10:43 PM Thread Starter
"Adam's Deep Wheel Cleaner has been a huge success! Even bigger than we anticipated! The first 275 gallons has sold out and most of our second batch is already spoken for as well. We are working as fast as we can to get all of your orders bottled and shipped in a first ordered, first shipped basis.
If you have not received tracking information for you order yet, we apologize and we anticipate having almost all of the orders fulfilled by Wednesday this week at the latest. Needless to say we were caught off guard by the response and this is shaping up to be one of our biggest new product launches to date.
Again we are very humbled by the overwhelming response to our new Deep Wheel Cleaner and we sincerely apologize for any small delays in getting your orders out the door. If you have absolutely any questions at all about the status of your order please email us at [email protected] with your order number and we'll be happy to update you on its status.
Thanks so much for your business, we truly appreciate it!"
post #8 of 9 (permalink) Old 03-07-2013, 10:26 PM Thread Starter
Last couple hours baby!!
post #9 of 9 (permalink) Old 03-08-2013, 08:46 PM Thread Starter
Thank you to all our customers, and maybe a few newcomers, who ordered the New Deep Wheel Cleaner and Lug Nut Brush. We are already receiving excellent feedback and praise on how well its working for the first people to receive their shipments and we want your feedback as well. Once you've had a chance to use the cleaner please post your experiences on our forum (www.AdamsForums.com) and submit a review to the product pages.
SUBMIT A DEEP WHEEL CLEANER REVIEW >>> NEW! Adam's Deep Wheel Cleaner
SUBMIT A TRIM & LUG NUT BRUSH REVIEW >>> NEW! Adam's Trim & Lug Nut Brush
Thank you all again for your business and I hope you have an excellent weekend. Remember detailing season isn't far away!
