Not sure with catalytic converter is bank 2 for 2007 Ford Taurus. - Page 2 - Taurus Car Club of America : Ford Taurus Forum
 2Likes
post #11 of 17 (permalink) Old 05-21-2019, 09:22 AM
Cat outlet temp should be higher than inlet temp by 100 C at least. That, along with the 430 code, means cat is dead. Either replace the cat or, if the cat isnt clogged and reducing performance and MPG, spend $20 on "MIL eliminators", which look like the old spark plug antifoulers. Simply remove post cat O2, screw in the adapter, and screw the O2 into the adapter. They work.
post #12 of 17 (permalink) Old 05-21-2019, 12:38 PM
Thanks. Think I will replace them if need be. I put it in the garage just to be sure. So we'll see.
blondechic451 is offline
post #13 of 17 (permalink) Old 05-22-2019, 06:18 PM
The mechanic said my front catalytic converter is so stomped up, that he doesn't know how I'm driving the car. I went ahead and changed my 02 sensors just to see how it does. CEL came right back on.
post #14 of 17 (permalink) Old 05-29-2019, 11:43 AM
I put an old sensor downstream I thought was still good. A new one upstream. Get my CEL checked and now it's pulling two codes for the downstream sensor but P0430 is gone. Put a new on on there this morning and the CEL went away. I also bought a new cat online because my mechanic said I needed one. It's going to cost $60 just to return it.
post #15 of 17 (permalink) Old 05-29-2019, 12:34 PM
Year: 02
IF.. your mechanic is competent and thorough, he would have removed the upstream sensor and attached a pressure gauge. If pressure is >3psi convertor is restricting, and should be replaced. I wouldn't return your cat; as you will need it sooner or later.
rsteve56 is offline
post #16 of 17 (permalink) Old 05-30-2019, 08:33 PM
You aren't kidding! That PO430 code came back on today.
post #17 of 17 (permalink) Old 06-13-2019, 11:54 AM
After that code came back, I had to unplug the battery for another repair and it never did come back on. I've been out in that car at least 15 times. I don't know how thorough the mechanic was that looked at my car. I wasn't there when he looked at it. He could of just been assuming it was bad by the CEL code. My car never had any symptoms of it being bad. Not replacing it if I don't have to, and currently, it doesn't appear that I need to.
Used Taurus/Sable Finds - Post them here! bull geek Taurus and Sable General Discussion 988 05-04-2019 01:09 AM
P0430 2007 Ford Taurus NEED HELP ASAP Mvp Swagz Maintenance and Repair 7 03-30-2018 09:58 AM
Ford will not acknowledge their own recall! (1986-95 Taurus, Sable, Continental) Brian_05_SEL Taurus and Sable General Discussion 11 09-14-2013 10:15 PM
Recall 96s51 joshuapace Maintenance and Repair 2 01-16-2006 01:25 PM
