Adding a keyless entry keypad on a G1 Taurus - Page 2 - Taurus Car Club of America : Ford Taurus Forum
 3Likes
post #11 of 12 (permalink) Old 05-22-2019, 06:25 PM
michaelt62's Avatar
Year: 2014
Engine: 3.5L Ti-VCT V6
It depends on what system you wish to install. Keyless Entry, Remote Keyless Entry, and if you wish to have the Auto Lock & Auto Relock active(Keyless Entry uses a seat sensor/reverse signal input/door ajar input), (Remote Entry uses a brake pedal input/reverse signal input/door ajar input). If you only want Keyless Entry (No Auto Lock, Auto Relock,Trunk Release or Illuminated Entry) then you only need the keypad, Keyless Entry Module & the wiring(providing you already have power door locks). The early modules only had 2 connectors that you will need to connect to 12V & Ground and the 8 wires going out to the keypad. Pic's below of some of my installs. !st pic. 1978 Lincoln Continental Mark V. 2nd pic, 2000 Lincoln LS & 3rd pic, 2001 Ford Taurus. Also, not all keypads are the same, earlier ones have a designated wire for each button, later ones use internal diodes so the wire harness uses 3 less wires.
ID:	208775   Click image for larger version
ID:	208777   Click image for larger version
sheila and TaurusLX86 like this.
michaelt62 is offline
post #12 of 12 (permalink) Old 05-25-2019, 04:47 PM Thread Starter
Thanks a bunch! Keypad, module, and wires. Got it. When I buy a G1 Taurus wagon I'll do the installation.
TaurusLX86 is offline
2011 SEL - Keyless Entry Panel replacement? Ctrl-Alt-Rage 5th and 6th Gen Maintenance and Repair 10 12-22-2017 08:49 AM
Keyless entry keypad Triton3.5 Electronics, Security, Audio and Visual 8 06-28-2017 08:40 PM
Keyless Entry Remote progamming ? Opfor2 5th and 6th Gen Electronics, Security, Audio and Visual 12 02-15-2016 10:29 AM
Adding Keyless Entry to 2004? NyteFire Electronics, Security, Audio and Visual 36 09-16-2013 11:02 AM
02 keyless entry compatible with 04 jackson521 Electronics, Security, Audio and Visual 2 05-06-2013 07:31 AM
