HELP TRANSMISSION - Page 2 - Taurus Car Club of America : Ford Taurus Forum
post #11 of 18 (permalink) Old 10-24-2018, 01:06 PM
Year: 2004
Have you ever installed a new ignition coil on the car. I had a stumble at 45 mph and thought it was a issue with the locking torque convertor but finally it threw a code and it was the coil. Look at the coil for cracks which will eventually lead to issues. Look at my thread. https://www.taurusclub.com/forum/82-...-40-45mph.html
+1 That's what I was thinking too when I mentioned it might be the engine and not the transmission. A coil pack is a lot easier to replace than a transmission
Kevin
Current stable
2004 Sable LS Prem DOHC
2003 Taurus SES Vulcan
2002 Taurus SES DOHC
Retired:
2001 Taurus SES DOHC
2000 Taurus SE Vulcan
1994 Sable GS
1988 Taurus LX
Hornswaggle is offline
post #12 of 18 (permalink) Old 10-24-2018, 01:37 PM Thread Starter
Derrick2001's Avatar
Year: 2002
Talking
Thanks, I can't wait till I get out of school so I can go take a look at it!! and I'm going to ohm it out too and see if it's going bad or anything yet and inspect it for cracks.
Derrick W Davis Jr.
Derrick2001 is offline
post #13 of 18 (permalink) Old 10-25-2018, 08:14 AM
Year: 2004
When the coil pack went bad on my '01 you could easily see a crack but I recently had to replace the coil pack on my '02 and it showed no visible cracks or issues so even if you don't see anything wrong with it don't rule it out.
Kevin
Current stable
Retired:
1994 Sable GS
1988 Taurus LX
post #14 of 18 (permalink) Old 10-25-2018, 08:46 AM
Moderator
Ohming it out will tell you virtually nothing, as the ohmmeter doesnt put the coils under the 20 kV stress they see in operation. If you replace the coil pack, use only The Motorcraft or BWD (Borg Warner) unit. Cheap aftermarket ones are just that.... cheap junk.
post #15 of 18 (permalink) Old 10-25-2018, 09:35 AM
^^^^+1 I ohmed out the coil pack in the pics I attached and it showed perfect. Not saying the coil is the issue but if you have cracks you will be destine to have issues. It was my cause on what I though was a convertor lock up issue.
Automender12345 is online now
post #16 of 18 (permalink) Old 10-27-2018, 04:09 AM
Year: 2000
Just the verbage alone, "chugged" ,makes me feel like it's not the tranny. The ax4s has more problems than the ax4n
IkeNewton is offline
post #17 of 18 (permalink) Old 10-29-2018, 09:29 AM Thread Starter
Year: 2002
UPDATE!!
Turns out that the PCV elbow was cracked all over... and I replaced the elbow and the PCV valve and she is running a lot better and able to shift at 5k rpm again. it does hickup a little however but I see that its still spitting oil out a little on the hose that goes from the elbow to the PCV valve so I'm going to buy more hose all that rubber was rock hard!! Problem fixed!! All that sucktion at high rpm was making it lea cause it had enough sucktion to pull air through the cracks at low rpm it did has as much sucktion to pull the air through.. YYYAAAYYY!!!
Derrick W Davis Jr.
post #18 of 18 (permalink) Old 10-29-2018, 02:46 PM
Your manifold vacuum is low at wide open throttle. Highest at idle or going down hill with throttle closed.
Transmission slippage kdannyk Engine and Drivetrain 4 07-07-2016 06:20 AM
AX4S Transmission Rebuild Guide and Questions wagon1212 Maintenance and Repair 4 01-12-2016 01:52 PM
Need Help Replacing Transmission norcalkb Engine and Drivetrain 13 06-29-2014 12:47 PM
Gen 3/4 AX4S (AXOD-E) Transmission Guide Ultimatum Maintenance and Repair 33 04-29-2013 12:12 PM
You may post new threads
You may post replies
