Spring Projects - Page 3 - Taurus Car Club of America : Ford Taurus Forum
post #21 of 23 (permalink) Old 03-22-2014, 12:20 AM
ShoGuy479's Avatar
Hmm. This spring....
Trans Flush on the SHO
Replace trans in the S-10 (Stock 700 couldn't handle the 388)
Rebuild brothers 390FE
Rebuild 4.6L and find Cobra heads and Intake.
Find decent mule platform for the 4.6l bull test swap
The list just keeps growing....
ShoGuy479 is offline
post #22 of 23 (permalink) Old 03-22-2014, 10:19 AM
Tom S's Avatar
Year: mult
All for the 03
Driving lights
PCM flash or a tuner to address some shifting and idle stuff I do not like
Pull injectors for a bench leak test
Getting closer to the time to pull off the winter tires
Tom S is offline
post #23 of 23 (permalink) Old 03-22-2014, 11:01 AM
Former Moderpony
Dschinghis Kahn's Avatar
I've really kind of started already/not stopped.
-Getting two new tires (Cooper) today to finally replace the two that were chewed up by the failing original struts. If I have to put up with the horrendously loud and vibrate-y tires any longer I'll lose it.
-The bull got the radio thoroughly cleaned last week (as in, taken apart and cleaned with soap and water) and reinstalled. The rest of the interior will be cleaned soon too.
-Today or tomorrow I'll probably replace the blown driver's door speaker too.
Originally Posted by sousa632 View Post
My list.....
Rear strut rod bushings (tomorrow hopefully)
Windshield
Motor mounts
Clean up/repair the rust around the dog legs
Oil Change
Find reason for oil leak around oil filter
Give it a GOOD cleaning inside and out
Get correct Sable floor mats
Paint the calipers?
Dip the rims
I'm sure there will be more things to do.
Good luck with that. I've tried twice now, it just reappears shortly after. Looks like there's two pieces of metal, with the moisture causing the rust between them. I'm guessing the only way to deal with it is to cut the leg out and weld some new metal in.
Dschinghis Kahn is offline
Rear Spring Replacement Time Exocet Suspension, Handling and Brakes 4 03-21-2014 09:54 PM
need help rewinding a clock spring? 666 Maintenance and Repair 16 02-09-2014 08:35 AM
Rear Spring Observations and Questions sable2000 Suspension, Handling and Brakes 28 01-19-2014 01:25 PM
99 Eibach Lowering Spring Part Number??? zebrasinamerica Suspension, Handling and Brakes 2 09-20-2013 09:29 PM
Advice on replacing a valve spring jrandallc Maintenance and Repair 9 09-05-2013 09:42 AM
