Pictures of my 2005 Taurus. - Taurus Car Club of America : Ford Taurus Forum
post #1 of 9 (permalink) Old 04-27-2013, 06:46 PM Thread Starter
As many are aware I no longer have my blue 1997 Taurus no more. Sold that back in February of this year. I took possession of my parents 2005 Taurus now which they bought used in 2006. I had it since about November when they bought a new 2012 Camry through me and my job at a Toyota dealer.
This 2005 had just under 112,000km when I got it. I have all the maintenance records and receipts from the time they owned it. They installed a heavy transmission cooler and electric brake control for a tent trailer they hauled for the first 4 years they had it. Anyhew since I put the car on the road, I installed new front pads and rotors, steel coolant line assembly (see my write up), and re-charged the A/C system. Other then that I upgraded the radio to a mach RCU, wood grain bezel around the stereo and installed the oil pressure and volt gauge that I had in my old Taurus.
My plans in the near future are a new battery (tested bad at work, but it still starts the car fine for now), a new paint job to fix the rust starting and get rid of the rest of the cosmetic damage, and install new speakers to replace the stock ones and installed the tweeters.
the_intimidator_02 is offline
post #2 of 9 (permalink) Old 04-27-2013, 07:12 PM
They were hauling a pop-up trailer with a Taurus! Did the original transmission survive? I sure hope the heavy duty transmission cooler was installed proactively instead of reactively.
behlinla is offline
post #3 of 9 (permalink) Old 04-27-2013, 07:25 PM
It's great to get a used car that you know everything about. Think about soaking the wheel well and doglegs with an oil from inside the trunk to stop the rusting. I have three and when they are gone I afraid I will be moving to another brand since the Fusions are small and the new Taurus are to big. But since I usually get about 15 years from each, my 2006 should last until 2021.
post #4 of 9 (permalink) Old 04-27-2013, 07:36 PM Thread Starter
Trans cooler was put in prior to the trailer being hauled. And it's the original transmission, never had an issue with it. They flushed it at the maintenance intervals. It's do for a fluid change again, but that may have to wait for now. The fluid it still good. As for oiling the car, it's been undercoated by me since 2007. The inside of the dog legs are well coated and so are the rockers, they're still solid as they were new. I have kept it undercoated every year and made sure it was well coated because I knew at some point I'd have the car.
post #5 of 9 (permalink) Old 04-27-2013, 11:15 PM
Trader Score: 7 reviews
I definitely liked the blue on your old car...unique, nice color.
Silver is a nice shade too on the 4th Gens. Well suited when cleaned up. Hope the 05 provides you with good service. You have the right motor and trans under the hood.
Funny seeing the speedometer in kilometers...don't see many pics of KPH on here.
--Nick
bull geek is offline
post #6 of 9 (permalink) Old 04-28-2013, 06:00 AM Thread Starter
Everyone that seen the car really liked that blue. I was thinking of painting this car the same blue, but it would cost significantly more to have to paint the door jams, inside the trunk lid, etc. Nothing I hate more on a car is a nice paint job and then open the door and it's a completely opposite color. So I'm going to keep it a silver color, and add a pearl like the old car. Only downside the pearl may not be too noticeable because of the lighter color of silver. But I won't know till it's painted I guess.
post #7 of 9 (permalink) Old 04-28-2013, 08:47 AM
JIMMER's Avatar
Very nice. She looks mint. As a fellow Canuck, I know how hard it is to keep rust away from these.
James
2002 TAURUS SE - 3.0L VULCAN - 5 SPEED
TORONTO, ONTARIO.
Ride of the Month - Sept. 2011 - coolfords.com
Ride of the Quarter - 1st Quarter 2012 - teamtos.ca
Car of the Month - July 2012 - TCCA
Car of the Year - 2012 - TCCA
Video:
JIMMER is offline
post #8 of 9 (permalink) Old 04-30-2013, 11:19 AM
The White Falcon's Avatar
Year: 2010
Engine: 3.5L Cyclone V6
How hard was the voltmeter install? Obviously I can't put one where yours is, but...
The White Falcon is offline
post #9 of 9 (permalink) Old 05-01-2013, 10:23 AM Thread Starter
Volt meter is not hard at all, just have to tap into anywhere there is power when key is on. Both gauges are electronic and require four wires to run each. Black wire is ground, red wire is for +12V constant, purple for +12 accessory, and green for signal, in my case. If you were to get a mechanical gauge, you would only need +12V with accessory and a ground.
The one thing I like about these gauges is they have a warning system that I can set to my preference. When the gauge goes either below or above the min/max I set it at, it will flash the back light orange on and off. When the gauge gets into the normal range, it goes back to the blue and white back light.
Alaskan Taurus Owner Condilly Introduction Forum 4 04-27-2013 01:44 AM
OBD II Scan tool canít connect to 2005 Taurus computer. qcy2k6 Maintenance and Repair 5 04-26-2013 01:59 PM
Mustang wheels on a 2001 Taurus? Sardog Aesthetics, Interior, Wheels and Tires 4 04-16-2013 10:30 AM
Paint Colors - Taurus Sable unit731 Maintenance and Repair 8 04-15-2013 10:50 PM
'05 Taurus, making it mine zolson Aesthetics, Interior, Wheels and Tires 55 04-13-2013 04:01 PM
