2105 limited rear brakes - Taurus Car Club of America : Ford Taurus Forum
 2Likes
  • 1 Post By sheila
  • 1 Post By chartmaker
post #1 of 4 (permalink) Old 03-17-2019, 09:56 AM Thread Starter
I have a 15 limited and the passenger side rear caliper seems to lock up and heat up. It never seems to fully release and wears the pad and rotor down in no time. None of the other calipers do this. Any ideas ??
Hobiewun is offline
post #2 of 4 (permalink) Old 03-17-2019, 10:35 AM
Seized slide pins, sticking caliper or faulty flex hose?
kekaye56 likes this.
sheila is online now
post #3 of 4 (permalink) Old 03-17-2019, 01:52 PM
I would like to add parking brake. Most likely fail on the pas rear.
chartmaker is online now
post #4 of 4 (permalink) Old 03-19-2019, 09:13 AM
Year: 2014
Engine: 3.5L Ti-VCT V6
On mine, the caliper bracket wasn't machined correctly and had a taper to it. As the pads wore, the pad backing plate would wedge into the bracket causing it to drag, heat up and score the rotor. After burning 2 rotors i figured it out and replaced the caliper.
1988 Ford Mustang LX 5.0L
Mustang5L5 is offline
Drum Brakes and Rear proportioning valve rmc1926 Maintenance and Repair 6 04-08-2017 10:22 PM
Weak rear brakes...load valve siezed? wjc Maintenance and Repair 4 09-05-2016 06:06 AM
2004 Rear Drum to Disk Conversion w/Active ABS Sensors leonedog Suspension, Handling and Brakes 7 07-02-2016 12:30 PM
Rear Drum Brakes Problem Joerules Suspension, Handling and Brakes 6 09-12-2014 06:44 PM
Brakes Dragging on 1993 Taurus LX with Discs Front & Rear & ABS Barkentine Suspension, Handling and Brakes 10 04-17-2013 04:15 PM
