2010 Ford Taurus SEL 2wd - Taurus Car Club of America : Ford Taurus Forum
post #1 of 6 (permalink) Old 02-19-2019, 10:56 PM Thread Starter
Hello! I’m new to this forum and have a shaking problem with my car. It was involved in and accident that bent the rim, knuckle and strut on the passenger front. I have a pretty good shake that’s noticeable above 50mph. I have replaced 3 sets of tires! One pair being used, one winter and one summer pair “new” and have had the tires balanced at least 10 times, replaced strut, lower control arm with presses in ball joint, outter tie rod, kunckle/spindle, rim, cv axle, sway bar link and inner tie rod on the driver side. Still nothing helped the shaking!! I jacked the car up and noticed anything over 25mph it starts shaking with or without the tires mounted, so I thought I had bad rotors. NOPE I took them off also and had the shaking... what can I do to get rid of this shaking?? Any help isn’t greatfully appreciated!
Jocamo is offline
post #2 of 6 (permalink) Old 02-20-2019, 12:34 AM Thread Starter
Idk why some of the words came out weird...?
Jocamo is offline
post #3 of 6 (permalink) Old 02-20-2019, 07:50 AM
Year: 2011
Engine: 3.5L Cyclone V6
Wheel Bearing hub
Martyx11 is offline
post #4 of 6 (permalink) Old 02-20-2019, 03:57 PM Thread Starter
Brand new passenger wheel bearing. Right side suspension components are mostly off and literally everything seems perfect.
Jocamo is offline
post #5 of 6 (permalink) Old 02-20-2019, 05:15 PM
d3500ram&taurus's Avatar
Year: 2002
If the car was involved in an accident that cause damage to the components that you describe, there could possibly more of the frame/ body that is out of kilter to give the symptoms you relate.
You may need to take it to a body shop that has a laser frame-straightening rack to compare your vehicle to mfgr specifications... there could be some part of the support structure for the steering and suspension components that is out of alignment. A competent body shop should have this equipment to check for you and provide a report.
2010 Taurus SEL
2002 Taurus SE
2005 3500 Dodge Ram
d3500ram&taurus is offline
post #6 of 6 (permalink) Old 03-06-2019, 11:19 PM Thread Starter
The accident only bent the rim, strut and spindle, but I thought something else was bent or messed up because I felt the vibration at highway speeds. It was on a frame rack and perfectly straight.
Jocamo is offline
ray shieh / 2010 ford taurus SEL 3.5L [email protected] Introduction Forum 4 01-05-2019 04:57 AM
2010 Ford Taurus SEL eriley Introduction Forum 2 10-26-2018 03:43 PM
Your Car History 145hp Other Rides 59 02-16-2015 09:17 PM
Ford will not acknowledge their own recall! (1986-95 Taurus, Sable, Continental) Brian_05_SEL Taurus and Sable General Discussion 11 09-14-2013 10:15 PM
Recall 96s51 joshuapace Maintenance and Repair 2 01-16-2006 01:25 PM
