Spring compressor for replacing front struts - Page 3 - Taurus Car Club of America : Ford Taurus Forum
 15Likes
post #21 of 35 (permalink) Old 02-23-2019, 11:04 AM
RLW001xxx's Avatar
Year: 2010
Engine: 3.5L Cyclone V6
Just curious why you are replacing the springs? Just to save time? I imagine you will have to compress spring to remove the struts anyway.
2010 Ford Taurus Limited.
RLW001xxx is offline
post #22 of 35 (permalink) Old 02-25-2019, 08:25 AM Thread Starter
Year: 2014
Engine: 3.5L Ti-VCT V6
Yes, to save time by building my own quick strut. With 3 kids i just don't have a whole lot of time on the weekend to wrench on a car. I'll assemble the struts ahead of time. Swapping a quickstrut in is pretty quick. No compressor needed for that step.
That's really the only reason i bought springs. If i was a single guy without kids, i'd spend the money i spent on the springs on beer instead, call a few buddies over and milk that job out.
1988 Ford Mustang LX 5.0L
Mustang5L5 is offline
post #23 of 35 (permalink) Old 02-25-2019, 12:38 PM
Year: 2013
Originally Posted by Mustang5L5 View Post
Shipping costs will vary so i'll leave those out.
Strut mounts $33 each from rockauto.com
Struts $96 each from rockauto.com
I applied the 5% discount code so that total was $247 before shipping.
pair of strut top nuts were $7 shipped from an Ebay vendor selling ford OE parts.
Springs were from www.getoemparts.com by searching the Ford part number i needed: $41 a spring, plus shipping and tax
So $336ish plus shipping costs (maybe $30 more).
The monroe struts came to $259 on rockauto.com with 5% discount and not including shipping. So basically another $77 or so to build my own Ford quick-strut.
I did look for used springs, but found it was actually cheaper to buy a brand new Ford spring. I'll likely pull the springs from my orginal struts and see if i can resell them.
That's really not that bad for struts and parts that you know will easily last 50K + miles
james27613 likes this.
terbob3 is offline
post #24 of 35 (permalink) Old 02-26-2019, 11:31 AM Thread Starter
Year: 2014
At 100K, my ride doesn't really feel that bad. Only doing this because my pass side strut mount it knocking away pretty good. I probably could have just change the strut mounts, but while i'm there i figure I just do new struts anyway.
Realistically, i probably only have another 20-30K with the car left before i'm looking to move on. I want a SHO
post #25 of 35 (permalink) Old 03-01-2019, 09:33 PM Thread Starter
Year: 2014
Ok. Started working on this. Really glad I ordered springs and did this ahead of time for 2 reasons.
Got my springs in. They really had to be compressed down quite a bit to fit. I ended up using two pairs of compressors to do it. I'm sure one set would have done the job, but using four gave me a lot of confidence that if one slipped (or failed) the other three were there as backup. Nothing happened though. But it took nearly an hour (for one strut) to carefully compress and then release the spring in the proper groove in the strut.
First problem was torquing the strut nut. It's recessed down in the strut mount so I didn't have an offset 21mm wrench to grab it. So I kicked my feet up and searched YouTube and found a great idea.
Took a 21mm deep socket and enlarged the through hole to pass a 3/8" extension through. I then put a 10mm short socket on the extension, then slid the deep socket down on the nut. Held the nut with vice grips and tightened it all up. Worked great...after wasting time trying to figure it out.
Second reason I'm glad I did this ahead of time? One brand new FORD strut mount was bad out of the box. Bearing plate was loose and noisey and rocked. When I received the parts, I only inspected one. Had I been doing this all on the actual car, I can see myself have had the strut out and taken apart and only then opening the box and finding the bad part.
So, one strut done, and one to go after I get a new strut mount sent to me.
sheila and james27613 like this.
post #26 of 35 (permalink) Old 03-01-2019, 10:16 PM Thread Starter
Year: 2014
Here's the second strut mount
https://youtu.be/0wDlj94Qvlg
Not sure it's supposed to do that, but sending it back to Rockauto for exchange.
Sent from my iPhone using Tapatalk
post #27 of 35 (permalink) Old 03-01-2019, 10:28 PM
Wonderful thing about pneumatic impact gun is the speed of the gun and the inertia of the part. I have just put the nut on the strut shaft and hit it with the gun. The nut will spin on before the shaft starts to spin. It works taking them off also.
Automender12345 is online now
post #28 of 35 (permalink) Old 03-02-2019, 10:15 AM Thread Starter
Year: 2014
Yeah. I was hoping the impacts would do the trick and I could just ugga chugga the nut home, but they spun the shaft. Only way to tighten it was to use my little trick. Another reason i'm glad i built the struts ahead of time vs trying to get this all done with my car in pieces.
Usually when it comes to reassembly I prefer to leave the impact tools on the bench and use the torque wrench.
post #29 of 35 (permalink) Old 03-02-2019, 12:10 PM
^ Good job MacGyver, lol!
Mustang5L5 likes this.
post #30 of 35 (permalink) Old 03-02-2019, 01:14 PM Thread Starter
Year: 2014
There's also this tool if you are one of those "use the correct tool for the job" people.
I'm thinking about installing some front struts on my '05 Ford Taurus johnnyd41 Suspension, Handling and Brakes 15 01-31-2016 08:18 PM
2009 SEL Front Struts STowell23 5th and 6th Gen Suspension, Handling and Brakes 0 12-01-2015 11:46 AM
Pieces Needed for Front Strut and Spring Replacement aaroncgi Suspension, Handling and Brakes 11 11-11-2015 11:11 AM
Front struts replacement SoNic67 Suspension, Handling and Brakes 26 10-13-2015 07:58 AM
G3 Struts FINALLY Installed Jeff93and99 Maintenance and Repair 9 10-06-2013 01:49 AM
