2014 Taurus Rear Brake lines - Taurus Car Club of America : Ford Taurus Forum
post #1 of 2 (permalink) Old 11-21-2018, 05:45 PM Thread Starter
Year: 2014
Engine: 3.5L Ti-VCT V6
HI All,
I just put new brakes and new brake hoses on all 4 corners of my 2014 Ford Taurus Limited with 90k. However, my right rear brake line fitting got messed up. How difficult is it to replace the rear main brake lines?
I have actually already bought the rear brake lines from Ford. Catalog: TAURUS CPH 2010 Section: 206-06/17 REAR BRAKE LINES (FROM 06/15/2009) part number 9J279 Attachment below -
It looks like there are gas lines included as part of the assembly and the brake lines run from the master cylinder to the back brake hoses. So I am wondering what is involved in the replacement, I hope I don't have to drop the gas tank?
Thanks
JoeSwens is offline
post #2 of 2 (permalink) Old 11-27-2018, 11:41 AM
Year: 2014
Looks like you damaged the main line?
Normally, what i would do is just cut out a small 3-4" section, and flare my own line and install it. However, if you don't have a good flaring tool which can be quite expensive, i wouldn't attempt it.
Still though, rather than replace the entire main line and spend hours dropping things out of the way, id take it to a mechanic and just have them flare in a new line just in the damaged section
1988 Ford Mustang LX 5.0L
Mustang5L5 is offline
The Tamaro or I call her Sinnamon: A True Transformation!!! Tamaro Taurus and Sable Project Log 41 04-24-2018 04:11 PM
Stuck in park, no brake lights on a '95 Taurus LX orodreth_99 Maintenance and Repair 4 07-08-2017 12:37 AM
1998 Taurus - right rear disc brake not working wulfdog Suspension, Handling and Brakes 1 07-06-2014 12:57 PM
Parking brake & rear drum issue sgebbie Maintenance and Repair 9 02-02-2014 10:13 PM
